g35 clicking noise when accelerating
Old Nov 16, 2014 | 06:24 PM
davidredg's Avatar
I have a 2006 g35 6mt. When driving at a steady 2-3k rpms I can hear a ticking sound. When I clutch in to shift gears the ticking sound is still there. In neutral I can only hear it when revving the engine. Has anyone ever came across this problem? Help plz
Old Nov 16, 2014 | 07:30 PM
Urbanengineer's Avatar
Check your oil lol.
Otherwise it might just be the axle click.
Old Nov 16, 2014 | 09:58 PM
bchalks's Avatar
I agree with Urbanengineer. Could be low oil. Could be loud lifters (normal on these cars). If it sounds like its coming from the rear it could be the axle click which is very common
Old Nov 16, 2014 | 10:12 PM
DigitalDeviant's Avatar
Does it sound like this?
http://youtu.be/SrAbSkG4gbQ
If so, lifter tick. Check your oil.
Old Nov 17, 2014 | 12:45 PM
davidredg's Avatar
Thanks guys. Is this something to be concerned about setting that I fine an oil change 6k miles ago? The oil should last 10k...
Old Nov 17, 2014 | 12:58 PM
Don't ever let your oil last for 10k miles. Change it every 3k to 5k depending on oil.
Old Nov 17, 2014 | 12:59 PM
westsideblu's Avatar
Our cars burn oil a bit quicker then normal cars but 10k oil as advertised on the bottle doesn't actually last that long without having to add. Most cars burn off small amounts of oil ours burns a bit more. I usually change my oil around 3500-4k. Check the oil level. It's probably low after 6000 miles.
Old Nov 17, 2014 | 09:53 PM
JKL1031's Avatar
LAwd..
Old Jan 12, 2015 | 06:01 PM
infinitigman35's Avatar
ok so this is the most relevant thread i can find in regard to my issue. i have a axle click... i saw the video and everything about greasing up the shaft (giggity) and flipping the axle upside down. i just wanted to know what is the logic to this? does any one know? some one told me its like rotating your tires. sorry for jacking up this thread btw lol
Old Jan 12, 2015 | 06:39 PM
JKL1031's Avatar
I guess what u hear clicking are the two surfaces rubbing together and the grease lubes it. However I failed at resolving the noise with grease twice.
Old Jan 12, 2015 | 07:14 PM
That's G's Avatar
Damn. I've got the axle click also, but I'd hate to tear it apart and grease it with no results.
Old Jan 12, 2015 | 09:07 PM
JKL1031's Avatar
Tell me about it. I'm gonna lower the torque on the nut next time
Old Jan 13, 2015 | 03:42 PM
its worth a shot. the worst case.... new axle time. just really dont want to spent the money if its not needed.
rezendvous420
May 31, 2020 01:26 PM
Tolboothwilley™
Exterior-Vendor
Jul 28, 2016 12:42 AM
netcbc
Exterior - Body Parts CDN
Aug 21, 2015 09:50 AM
laksjd84
Jul 24, 2015 05:12 PM
papo020
Jul 17, 2015 10:30 PM
