slave cylinder
Old Dec 30, 2014 | 09:54 AM
johnw999's Avatar
slave cylinder
My 2008 G35 sedan is leaking hydraulic fluid for the clutch. I suspect the leak is at the slave cylinder (no evidence of a leak at the master cylinder). I've read that the 2007 G35 had a slave cylinder recall. Questions
1. Anyone have success in getting the dealer to replace the slave cylinder for 08+ as part of the recall?
2. Is it possible to replace the slave cylinder without dropping the transmission, bellhousing, or clutch assembly?
Thanks. I've searched, but I didn't find a clear DIY write up
Old Dec 30, 2014 | 05:17 PM
Almightyone's Avatar
I believe you have the Hr motor. If that is the case you have the concentric slave cylinder. The transmission would have to be dropped. Possible it might be covered under a recall. Might have to check with a dealer.
Old Jan 23, 2015 | 06:04 PM
daxamundo's Avatar
I'm sure you figured it out already, but you do in fact have to pull the transmission to get that part out. I wish Nissan had kept that as a part outside of the transmission, because I'm having my transmission pulled right now (2nd time in 6 months), due to what I expect is a failure with the slave cylinder. If you have to replace it, I suggest looking at some of the aftermarket options, which is what I am planning on doing this time around.
Also, if you managed to get the work done under the recall, please update the thread!
Aftermarket options I have found:
$325 - https://conceptzperformance.com/Cart...on.php?II=4593
$135 - http://www.stockwiseauto.com/product...RyAxoCSA7w_wcB
Old Jan 23, 2015 | 06:22 PM
G2B35AGN's Avatar
I have no experience with your issue, but I would go to the Recall Inquiry page on the Infiniti website-- http://www.infinitiusa.com/recalls-vin#/ -- and enter your VIN. If you are not listed, I doubt you'd be covered. I used this link to check every used car I looked at when I was shopping for my G.
KallDay86
Jan 8, 2016 12:42 AM
Mad A
Not G35 Related
Dec 8, 2015 01:45 PM
AL8782
Oct 3, 2015 10:26 AM
dcsbh1
Oct 1, 2015 03:15 PM
yosip1115
Sep 9, 2015 03:30 PM
