Help please: Transmission fluid
Old Jan 2, 2015 | 07:09 PM
$Coupe$'s Avatar
Sup everyone.. Hope yall enjoyed the holidays.
I have a few really quick questions. I checked my transmission fluid and it is really low to the point where it says hot. The color is also brownish(no sight of red).
My question is can I go purchase the correct transmission fluid for the car and fill it myself? Or is there more to this issue and I'll have to go to a shop for a drain/refill?
Thank you.
Old Jan 2, 2015 | 07:51 PM
Urbanengineer's Avatar
You can do this yourself. It's as easy as buying Nissan J or S Matic transmission fluid and draining it and filling it from the transmission when you have time.
Old Jan 2, 2015 | 08:25 PM
$Coupe$'s Avatar
Thanks for replying. Glad to hear its something I can fix myself. I've changed my oil plenty of times but have never fooled with the transmission before.
Old Jan 4, 2015 | 03:37 PM
Blue Dream's Avatar
I drove ttrank's car solo
It's just as easy to change the transmission fluid as it is to change the oil. One drain plug to open, drain, re-install drain plug and fill.
Old Jan 4, 2015 | 11:34 PM
coffeysm's Avatar
Thank you.
It's super easy to do. I bought 4/5 quarts of Idemitsu Type J or Nissan Type J, $1 pitcher at Rite Aid, and drained the fluid into that. I then replaced the same amount I took out back in the system, I recommend doing it while the car has sat overnight. I believe heat causes the fluid to expand, so you can get a false reading. I did this every 50-100 miles three or four times.
There is another more advanced method where you disconnect return line to a pail, run the car, and replace the fluid at the same time until it runs clear. I wouldn't do this unless you have another person though.
Old Jan 5, 2015 | 08:20 AM
Originally Posted by coffeysm
It's super easy to do. I bought 4/5 quarts of Idemitsu Type J or Nissan Type J, $1 pitcher at Rite Aid, and drained the fluid into that. I then replaced the same amount I took out back in the system, I recommend doing it while the car has sat overnight. I believe heat causes the fluid to expand, so you can get a false reading. I did this every 50-100 miles three or four times. There is another more advanced method where you disconnect return line to a pail, run the car, and replace the fluid at the same time until it runs clear. I wouldn't do this unless you have another person though.
That would be a flush... Which is "NOT recommended by the forum."
Old Jan 7, 2015 | 01:26 AM
coffeysm's Avatar
That type of flush is using the transmission itself though to change the fluid. It's not using a machine hooked up, which I thought is what most people are against.
g.spot
May 9, 2016 10:54 PM
f22raptor
Mar 18, 2016 08:50 AM
AL8782
Oct 3, 2015 10:26 AM
