P0705 Transmission issues
Old Feb 7, 2015 | 08:11 PM
joecrack's Avatar
So I have a 2004 sedan automatic. I have a problem where my car wont start because it doesn't sense that it is in park or even in neutral and it wont turn over. It will however see park on the dash when i roll it forward a bit or rock it back and forth. I am assuming that it is some sort of transmission selector switch involved here. I am just wondering if anyone has had this problem before and what the fix was.
Thanks in advance
Joey
Old Feb 8, 2015 | 12:01 AM
bluedevils95's Avatar
Hope this helps
http://nissanhelp.com/diy/obd_codes/p0705.html
https://m.youtube.com/watch?v=s8y_jbiYYsw
Old Feb 8, 2015 | 09:37 AM
joecrack's Avatar
Ok so the park/neutral switch is located where ? Does anyone have a part number ?
Old Feb 8, 2015 | 11:02 AM
Call the dealers service tomorrow morning.
Old Feb 8, 2015 | 12:06 PM
joecrack's Avatar
would it be the one here or is there another switch on the actual transmission ?
Old Jun 2, 2015 | 04:00 PM
joecrack's Avatar
Ok so I'm going to bring this back up if anyone knows about the pnp switch on these auto tranny please help
Old Jun 24, 2015 | 09:53 PM
joecrack's Avatar
So after a bit of a battle figuring this out it turns out it was a wiring problem .
This is the harness going into the transmission and all the wires are stripped and touching on the one side of the green plug and 2 wires are pulled out . Now to try to find a new harness and I think my problem should be solved .
This is just a heads up if you are having a similar issue to check this grommet thing . Btw it's a bitch to pull out
Old Jan 19, 2022 | 07:55 PM
subzero445's Avatar
2004 G35 Sedan 5AT autotransmission
HELP, No crank No start
Hello everyone, I have a 2004 G35 Sedan with auto transmission. I am having a problem where my gear indicator is blank and I cannot figure out the problem, I scanned the car and got a P0705, I don't know where the park and neutral switch is located, I spent hours under the car and didn't see it. I even went through my center console and looked at the Shifter and didn't see any issues. I've checked fuses in IPDM, I've checked all other symptoms. Can't seem to figure it out. Could someone please help me out?
Old Jan 21, 2022 | 01:01 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
It's bolted to the side of the valve body.
zcherub
Aug 30, 2015 05:04 PM
derres
Aug 28, 2015 03:27 PM
saskicker32
Aug 11, 2015 02:12 PM
wuppiedog
Aug 7, 2015 11:16 AM
newg37
Jul 26, 2015 09:32 AM
