Code p1273 (weird Symptoms)
Old May 11, 2015 | 04:50 PM
korfak's Avatar
Hi, I know there are a lots of p1273 Threads but i doesnt found anything useful by now.
This is my mod list
1. Intake Injen
2. Exhaust Greddy and test pipes (OEM HEADER)
3. Plenum Spacer (this happened before the spacer install)
If I reset the Battery so the code doesn't appear at the ECU, but after a day or 2, the car enter limp mode and the VDC and SLIP light turns on.
I just turn the car off and then restart, and the car just works again normally but the CEL appear.
The car works fine while cruising, the only other symptoms is low power at low RPM range between 3k and 4k there's is a Important delay. but after 4.5k the power comes back
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
KallDay86
Jan 8, 2016 12:42 AM
dcsbh1
Oct 1, 2015 03:15 PM
Detailed Image
Sep 28, 2015 07:04 AM
vamarris
Sep 26, 2015 12:56 PM
