Motordyne Spacer dyno test results
Old Mar 14, 2005 | 11:29 PM
  #121
Hydrazine's Avatar
Hi Pathis,
61 inch pounds is actually the high end of the spec. so it should be enough. As far as the light is concerned, if you had a air leak at the plenum it should show itself as a rough idle. The rough idle would be easy to notice. Also another indicator would be a hissing sound somewhere around the plenum. If you don't notice either of these its unlikely to be a air leak. Did you have all the MAF and O2 sensors connected when you started the car?
The last time I had a SES light come on was when I left the MAF sensor cable unpluged when I started the car. Try a ECU reset and see if it goes away. Sometimes thats all it takes.
Old Mar 21, 2005 | 01:40 AM
  #122
Pathis's Avatar
National G Club
Originally Posted by Hydrazine
Hi Pathis,
Yeah, I actually did the ECU reset and it cleared the light. However it reappeared when I got up to around 6500 rpm. Im thinking that its actually the new cats thats setting it off. Havent heard anything coming from the plenum or any problems idling so the spacer seems to be ok. btw Im really loving the mod. I definetly give it 2 thumbs up.
Old Mar 21, 2005 | 08:06 AM
  #123
jjellyneck's Avatar
My 3/8" spacer has been installed for nearly a week. At first I noticed a little bit more power, but now after 50+ miles of driving, the power is more noticeable. This might be the ECU adapting (I didn't do a reset). My other mods are high flow cats and a Z tube. The spacer is a great mod.
Old Apr 18, 2005 | 11:23 PM
  #124
Jp1's Avatar
Jp1
torque
61 inch pounds doesn't seem much but with aluminum it's plenty. Tony knows his stuff. Whatever you do....don't overtorque those plenum bolts. It's almost better to invest in a torque wrench vs a new tap and dye set. Yes the spacer adds power.
linedr89
Aug 17, 2015 05:11 PM
Raven7
Aug 14, 2015 04:40 PM
sick_sixspeed
Jul 20, 2015 10:25 PM
