Help! My car won't start, crank or nothing
Old Nov 30, 2015 | 08:31 PM
Jonjon93's Avatar
2006 Infiniti g35 coupe manual 6mt
113,xxx
My car was driving great all year. Until today I drove to Wendy's ate inside and I come back out to start my car and nothing no noise no lights,didn't crank or nothing car didn't even try to start. They are telling me it's the ignition switch but I don't wanna spend money on it and it won't be the part
Please help me
Old Nov 30, 2015 | 08:39 PM
saywat?'s Avatar
ugh no one told u to check the batt voltage?
Old Nov 30, 2015 | 08:41 PM
Jonjon93's Avatar
Well I checked the battery the battery turned out to be good, had it tested in two shops autozone and advance auto.
The batt voltage ?
Old Nov 30, 2015 | 08:48 PM
saywat?'s Avatar
so wat was the battery voltage ?
Old Nov 30, 2015 | 10:09 PM
ScraggleRock's Avatar
I read the title of this thread in George Lopez's voice. The one he uses when he's acting extra Mexican. Haha
Old Dec 2, 2015 | 08:46 AM
telcoman's Avatar
Veteran: Army
113,xxx
Please help me
The first thing to check is the individual cells in your battery.
Use a battery hydrometer
Then check the positive and negative cable connections with a voltmeter
How old is your battery?
Any corrosion on the battery terminals or cables?
Telcoman
Old Dec 2, 2015 | 09:40 AM
Jonjon93's Avatar
Telcoman
Battery is roughly 1 year old
The battery terminals looks alright, I can send pics if you like ?
No corrosions don't know about the cables
Old Dec 2, 2015 | 11:40 AM
telcoman's Avatar
Veteran: Army
I
I see you've started three different threads.
If you don't have the ability to use a voltmeter and follow instructions in the FSM I would suggest you have your vehicle put on a flatbed to the nearest Infiniti dealer to have them find the root cause of your problem.
If you are a AAA member there is no charge.
If you are not a AAA member you should probably join immediately.
Yes it is going to cost some money but what good is a vehicle that doesn't start.
It is not unusual to have a one year old battery fail
Battery terminals that look good mean nothing and sending photos is a waste of time.
You need to do logical testing or pay someone qualified to do it for you.
Being cheap about it may end up costing you more in the end.
If you did something to your vehicle prior to having this problem, undo it.
Good luck
Telcoman
Old Dec 2, 2015 | 06:18 PM
Jonjon93's Avatar
I
Good luck
Telcoman
all I did was turn my car off and went to go eat came back and bam nothing turned on
thechitoguy
Forced Induction
Oct 17, 2015 04:14 PM
thechitoguy
Oct 1, 2015 05:25 PM
