Did I trigger the P0340 code?
Old Feb 8, 2016 | 05:58 AM
bongoz's Avatar
Recently purchase a 2005 G35, 84k miles.
I will warn you sometimes I'm an idiot when it comes to cars.
On my 2nd time ever starting the vehicle, I turned the ignition and released it just barely before the engine started. Then immediately tried to start it again and as before I released the key just before the engine started. must have temporarily messed something up because after a few more tries I finally had to hold the key starting the engine for 3-4 seconds before the engine finally fired up.
Shortly after this incident I looked at my dash and noticed the "check engine soon" light.
Read the code and it was the P0340/cam sensor
I read online that some symptoms are hard starting.
Did i possibly trick the ECU into thinking I have bad cam sensors because of my stupid error when starting the vehicle for the 2nd time? I reset the code and have driven it for 30-40 minutes without the check engine light coming back on.
The vehicle does not have a hard starting issue as far as I'm aware. It starts up perfectly fine every time unless I'm an idiot.
Old Feb 10, 2016 | 02:00 AM
CV35Driver's Avatar
Simple Battery Reset and look for codes again after 50 miles of driving. Have a set of Cam Sensors and CrankShaft Sensors on hand though in case they are bad.
Chriswf
Mar 11, 2016 12:27 PM
Moskvitch
Feb 26, 2016 01:58 PM
jxxsun
Feb 4, 2016 10:43 AM
Markw
Feb 3, 2016 06:51 PM
Jorgebarrera
Jan 19, 2016 06:48 PM
