Thermostat leaking
Old Mar 18, 2016 | 07:51 PM
Lmunoz's Avatar
Thermostat leaking
Today I had the thermostat changed in my 08 Infiniti and it's leaking. Any tips or suggestions?
Old Mar 18, 2016 | 10:00 PM
hurleyguys's Avatar
take it back to where you got it done. if you did it then look really close to where it is leaking.
Old Mar 19, 2016 | 10:51 AM
Lmunoz's Avatar
A friend replaced it.- He put it on and pulled it off twice because it was leaking. Do you put a sealant on it and is there a process to it? Someone else said you put the sealant on leave it 15 min, start the car and let it heat up to help the sealant. I know some about cars but I'm still female and don't know everything when it comes to replacing parts.
Old Mar 20, 2016 | 01:12 AM
bigc's Avatar
Wings Nation
You don't need sealant. Just make sure you replace the gasket and torque the three bolts down properly (75 inch-lbs I think).
Old Mar 20, 2016 | 07:44 AM
telcoman's Avatar
Veteran: Army
Why did you change the thermostat?
Was there a problem with the old one?
Did you use the correct thermostat?
Did you or your friend follow the steps in the FSM?
http://www.nicoclub.com/FSM/G35/Sedan/2008/CO.pdf
See page CO-22
Telcoman
Old Mar 20, 2016 | 01:47 PM
coffeysm's Avatar
Not sure about the 08 on my 06 it was a metal gasket if I remember right. You can pick up some RTV or "the right stuff", which is pretty instant.
Phenomenon9
Aug 26, 2016 04:13 PM
PerryLancaster
Apr 30, 2016 08:20 PM
L-Spec
Southern California
Mar 18, 2016 04:26 PM
JMFeld02
Engine - Exhaust
Mar 14, 2016 10:58 PM
maxgee.
Mar 12, 2016 12:53 AM
