HELP Unknown troubles with my car
Old Mar 25, 2016 | 11:29 PM
Wade Graham's Avatar
So I recently got another g35 it's a 05 sedan . I love the car so far. Since day one it's had an issue sometimes when you start it it won't happen like the whole car goes dead so you have to pop the hood and reconnect the unit to the battery which is no big deal but yesterday as I was driving I felt this weird feeling as I was driving so at a red light I noticed my Rpms were moving even while I was stopped and when you drive it just is weird feeling like it sputters and the SES light came on after I got home yesterday . Should I be worried is this an expensive fix ? Does anyone know what's even wrong
Old Mar 26, 2016 | 07:03 PM
Jbox's Avatar
sounds like a misfire. Get the code read and see what it links up to. Could be just spark plugs and coil packs which is relatively inexpensive. Good luck!
Old Mar 27, 2016 | 08:48 AM
telcoman's Avatar
Veteran: Army
...Since day one it's had an issue sometimes when you start it it won't happen like the whole car goes dead so you have to pop the hood and reconnect the unit to the battery
Closely inspect your battery cables.
How old is the battery?
Have you tested it?
If it is the original one replace it
Make sure there is no corrosion and the clamps on the battery are tight so they cannot be moved by hand
Telcoman
Old Mar 28, 2016 | 11:02 AM
Mignav01's Avatar
Same thing happened to my camry awhile back. check the clamps which clamp onto your negative and positive battery posts. that may be it, mine was no good
edwinisdumb15
SOCAL Meetings & Events
Feb 7, 2016 09:57 AM
Treewax
Jan 25, 2016 11:32 PM
Kansas
Jan 22, 2016 06:42 PM
MVMNT
Jan 14, 2016 07:47 PM
jclose123
Jan 12, 2016 12:19 PM
