Injector Ohm specs - my new ones are slightly lower
Old Jun 8, 2016 | 10:19 AM
cfauvel's Avatar
the specs for the v6 injectors are
Injector Resistance [at 20°C (68°F)] 13.5 - 17.5Ω
I just bought new injectors from rockauto (hitachi) and they all range from 12.5 to 12.6, that's a full ohm difference than specs. Granted I'm not a 68 degrees F, more like 79 degrees inside the house.
should I be concerned?
Old Jun 8, 2016 | 12:06 PM
yosip1115's Avatar
You got that spec from the appropriate FSM, correct? They used a few different injectors throughout the years
Old Jun 8, 2016 | 01:00 PM
cfauvel's Avatar
good point - looks like I'm looking at a 2003
good point - looks like I'm looking at a 2003 document
http://www.nicoclub.com/FSM/G35/Coupe/2003/ec.pdf
changed the url to 2005 (a coupe though)
and got
Resistance [at 10 – 60°C (50 – 140°F)] 11.1 - 14.5Ω
I imagine the coupe and sedan injectors would be the same...right?
Old Jun 8, 2016 | 01:06 PM
cfauvel's Avatar
found the 2005 sedan ohm readings for injectors
indeed they are the same as the coupe, and 12.5 is within range, thanks for leading me to the obvious....('gotta be the right year dude')
Old Jun 9, 2016 | 09:41 AM
yosip1115's Avatar
Yeah, the injectors are all the same on the DE and revup cars, the HR ones are different (green) ones.
It is odd that they changed the spec if they are all interchangeable. Probably had service techs replacing injectors from a specific manufacturer because they were "out of spec" when they really weren't.
onelonelyg
Apr 4, 2013 09:21 PM
gameover
Nov 19, 2010 11:57 PM
98intrigue
Engine-Vendor
Apr 27, 2008 11:52 PM
gumpdriver
Archived Sales
12
Jul 17, 2006 04:40 PM
