Tuner in MD/Question.
Old Jun 20, 2016 | 07:07 PM
Pumacelled's Avatar
Does anyone in Maryland or nearby know of a good, reliable tuner that specializes with nissans/infinit's and tunes with osiris, uprev? Im considering Hills garage, is anyone familiar with this shop, have any experience? also my car is an 03 coupe, i believe pins for my ecu will need to be rearranged, would the pins need to be put back in place after the car is finished with the cable and software, if not would this cause issues when trying to read codes?
Old Jun 21, 2016 | 09:51 AM
LoSt180's Avatar
Hills Garage hands down. Frank did my tune, and is considered the local expert. Won't have any problems taking the car there. He should be able to answer your question about the pins, but those are swapped at the OBDII connector and are typically left alone after the tune.
Also, check out National G Club since you're in the area.
Old Jun 21, 2016 | 10:07 AM
Pumacelled's Avatar
Exactly the info I was looking for, thanks man. Also were you happy with the power you made? If I can ask, What mods did you have and how much power did you dyno at? What year is yours?
Old Jun 21, 2016 | 12:10 PM
LoSt180's Avatar
I was happy with the tune. He was in the middle of moving shops and used a new dyno at a different shop, so my overall power seemed low. Since it was a new dyno, he said it could have just been reading low. I apparently had a pretty good e-tune from a forum member on here going in, but they were able to squeeze out an extra 20 hp in the mid-range and about 7 at the top end.
My best friend got a 20-30 hp jump on his G.
I have an 06 6MT (revup engine) with Stillen intake, OEM Z-tube, a modified non-revup lower plenum (DIY MREV2), motordyne 3/8" spacer, AAM HFCs and a Fast Intentions catback exhaust.
Old Jun 21, 2016 | 01:19 PM
Pumacelled's Avatar
Thanks again , I appreciate the help, plan on giving them a call sometime today.
Old Jun 24, 2016 | 08:29 AM
superchargedg's Avatar
You cant go wrong with Frank at Hills garage
djwishuwur
V36 Interior, Exterior & Lighting
Mar 28, 2016 11:44 PM
jdmek100
Mar 28, 2016 03:21 PM
Sweet B
Mar 24, 2016 10:27 PM
Popey87
Mar 24, 2016 09:58 PM
