P0171 need help
Old Jul 5, 2016 | 11:48 PM
Popes's Avatar
P0171 need help
So I have a 2004 G35 sedan 5at and one night I filled in gas to full tank, I always filled up fill at 1/4 tank same gas station. About 40 mins into driving I noticed when I accelerated from a stop there would be a hesitation the the rpm would jump up to where it should be almost like the injectors is clogged?
So I changed the fuel pump it helped a little, changed spark plugs, crank, alternator sensor, cleaned throttle body and MAF also switched with another MAF that I know is working. So everytime I start the car and let it idle at around 40 minutes it will start to run rough and it will die unless give it gas, does this constantly. I haven't ran injector cleaner yet I'm wondering before I buy new injectors should I check anything else first?
Old Jul 6, 2016 | 01:47 AM
hurleyguys's Avatar
be sure to check there are no leaks after the MAF and before the O2 sensor.
any mods?
Old Jul 6, 2016 | 02:18 AM
Popes's Avatar
any mods?
Z tube and plenum space, I forgot to add that I retorqued the plenum bolts and have no air leaks. Which o2 sensor should I look at the top or near the cats
nrg1
Mar 20, 2016 01:51 AM
Jiggs1219
Feb 25, 2016 08:30 AM
David Sanders
Feb 20, 2016 10:51 PM
forestzemel
Feb 20, 2016 08:25 AM
Bean_VQ35DE
Feb 19, 2016 08:44 PM
