Building a bottom end
Old Oct 21, 2016 | 02:07 AM
Adrian Rivero's Avatar
Ok, so heres my first post so I'll try to keep it short( I'm not good at writing things like this).
So I baught a 2003 G35 with 100,000 miles with nasty oil consumption. I changed my valve guide seals but its still blowing smoke and burning oil so I need to change my piston rings.I figure why not build up my bottom end while I'm at it?
Only one problem, I'm a total noob at this, but maby with the help I get more people can benefit from the info
1. So first off whats Included in building a bottom end parts wise?
2. What are my options aftermarket and oem wise and what do they go for?
Old Oct 21, 2016 | 05:18 AM
Blue Dream's Avatar
I drove ttrank's car solo
Normally I'd delete this thread because as a n00b you have a responsibility to familiarize yourself with the forum rules. The header of this sub-forum specifically states "NO CAR QUESTIONS!" yet here we are.
However your post was not drivel so I'm moving it to the appropriate place.
Old Oct 24, 2016 | 04:04 PM
Swaglife81's Avatar
Building a bottom end is no easy task. But it is doable. Best to have help from a good mechanically inclined friend. I've read some great write-ups on builds. One was on 350z forum. It's more active these days. Here is a link to 10 tips to building a powerful and reliable VQ35DE.
http://www.revvedmag.com/engine-tech/engine/tech-10-tips-for-building-a-powerful-reliable-nissan-vq35de/
You will need some specialty tools for measuring certain degrees, clearances,etc.
Read all the DIY and build guides you can on the internet. Your answers can't be achieved from a thread post. It's not the easiest engine to build.
