Hesitation when accelerating in high rpm
Old Jan 4, 2019 | 03:23 AM
vq35rSolly's Avatar
DID you fix? I need this fixed ASAP
Old Dec 2, 2019 | 05:34 PM
Koco's Avatar
Problems
Acceleration after 40 mph Infiniti g35
Old Dec 3, 2019 | 12:28 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Take a video of a full wide open throttle pull from a standstill and another one of you punching the throttle wide open at 40 mph.
Old Dec 3, 2019 | 07:42 PM
Koco's Avatar
Problems
I'm going to take them.
do you have any idea what it can be?
Old Jul 25, 2020 | 12:57 AM
OdinR6's Avatar
08 G37s 6MT
Same issue on 08 G37
Ive been having this issue as well. It has gotten better somewhat but ive replaced so much. Injectors, fuel pump housing, fuel pump, alternator. Ive heard that it may be my acc. Pedal but i thought it to be too weird to replace it. Log wise i am leaning out. I installed a fuel pressure gauge to see that it does go down WOT. Lethal numbers for my fuel pressure. You can hear the fuel cut same as in the video.
Let me know if you have fixed this issue.
my voltage to fuel pump under load is fine. No leaks at dampener. My tuner said he ls never seen anything like it .
Old Jul 25, 2020 | 05:51 PM
cleric670's Avatar
BANNED!!!
How low does it hit at max rpm?
Old Feb 7, 2021 | 08:51 AM
djvillin602's Avatar
Any luck?
My car just started doing the exact same thing! Have you had any luck narrowing down the issue?
Gabe Puzon
Oct 22, 2021 11:00 AM
shibbykins
11
May 17, 2016 12:09 AM
hans127
Jan 17, 2008 03:42 AM
AlcatrazT2
Jun 26, 2006 12:30 PM
