Synthetic vs. Conventional
Old Nov 26, 2017 | 10:27 AM
Kitzhaber's Avatar
I drive a 2004 Infiniti G35 and use synthetic oil. It burns a quart per 1,000 miles. This is rather expensive. If I switch back to conventional, will it burn less oil?
Old Nov 26, 2017 | 11:55 AM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Short story YES, conventional is a larger molecule so it's harder to squeeze past work components.
Long story, words words, scientific theory with opintion, Google or search for posts here, debate ensues.
Old Nov 26, 2017 | 12:55 PM
Urbanengineer's Avatar
Just change it when recommended, check every other fill up. Convi is fine.
Old Nov 26, 2017 | 07:51 PM
Edgarc6789's Avatar
I have the same exact problem.
Next month in switching to conventional oil
Old Nov 26, 2017 | 09:05 PM
gary c's Avatar
Synthetic fluids run cooler and cleaner, there's no way in hell I'd ever go back to using conventional oil...regardless of cost!
Gary
Old Nov 27, 2017 | 12:43 PM
Edgarc6789's Avatar
It really isn't expensive it's just that I have to keep adding oil
It's only $26 for 5 gallon Mobil 1 fully synthetic
Old Nov 27, 2017 | 03:28 PM
cleric670's Avatar
BANNED!!!
...debate ensues.
Old Nov 27, 2017 | 05:20 PM
Conissah's Avatar
Take your pick.
Click Meeeee
Old Nov 27, 2017 | 05:39 PM
cleric670's Avatar
BANNED!!!
Given the small sample size for nearly every oil and knowing absolutely NOTHING about each engine, including existing wear and driving conditions I would put zero stock into that thread.
Old Nov 28, 2017 | 06:48 AM
ScraggleRock's Avatar
Gary, for as much as you are an advocate for OEM specs, it's funny that you won't use conventional even tho the VQ was designed to run on conventional. Nothing to do with cooler/cleaner, but more likely to do with valve clearances. It's no coincidence that everyone using synthetic has noticable valve ticking.
Old Nov 28, 2017 | 09:49 AM
gary c's Avatar
From my first oil change (1K miles) I've been using 5W/30 Mobil1 synthetic in SLICK'S engine and didn't begin using AMSOIL until she had 5K miles on her clock like they recommend! Valve noise, no that would worry the **** out of me!
Gary
Old Dec 2, 2017 | 01:27 AM
Conissah's Avatar
I can confirm this in my car. She HATED Pennzoil Synthetic, engine sounded like butt. Promptly switched back to good ole Castrol conventional.
DATVQ
May 9, 2018 08:18 AM
FreshLikeAG
Apr 22, 2018 08:17 PM
Thoeun Se
Nov 5, 2017 03:13 PM
TheIronYuppy
Cars for Sale CDN
Oct 27, 2017 07:46 PM
ZORG
Oct 21, 2017 10:55 PM
