engine swap question
Old May 6, 2018 | 10:09 PM
TCSG35X's Avatar
Hey guys I have a question. I have an 07 G 35X i bout a few months ago and the car has all kind of problems. The engine is no good and I wanted to known if i get a G 37X engine can i use the G 35X transmission?
Old May 6, 2018 | 10:53 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
You should have a VQ35HR motor, it has two intakes, one on each side of the motor. You can replace with one from a G/Z/M infiniti.
Old May 6, 2018 | 10:54 PM
cleric670's Avatar
BANNED!!!
G37 used the VQ37VHR which is not a compatible donors.
Old May 6, 2018 | 11:01 PM
TCSG35X's Avatar
yeah thats my motor. But can i use my old tranny?
Old May 6, 2018 | 11:08 PM
cleric670's Avatar
BANNED!!!
No, the 5 and 7 speed transmissions were very different, the VQ35HR uses a 5AT, the VQ37VHR uses a 7AT.
If you swapped the entire system including ECU then anything is possible if you have the electrical and mechanical proficiency to build custom mounts, custom harnesses, integrate to the existing combination meter is probably workable but the best bet would be to custom fit the proper combination meter.
Why not just buy the right motor for your vehicle instead of spending $10-15k on a custom engine swap. Besides the VHR is cool and all but it's a better route to swap an LS or something like that.
Old May 6, 2018 | 11:12 PM
TCSG35X's Avatar
ok cool. Looks like I'll be looking for a used motor then, cause i know to rebuild it it will coast about 2k just the work.
SuprachargedG35
Drivetrain
Feb 14, 2018 10:52 AM
Theanimedude
May 5, 2008 04:13 PM
MikeIvoryg35
Jun 25, 2006 09:34 AM
