Strange throttle issue
Old Jun 20, 2018 | 11:35 PM
ka8man's Avatar
so I’m trying to diagnose an issue with a 03 Sedan and I’ve never run into it before. When I press the throttle down it is very slow to rev, if I blip the throttle it revs when released. I’m thinking it’s the throttle position sensor or the Accelerator pedal position sensor but when I connect my OBD 2 scan tool the only pending code is a NATS malfunction but it reads the key jus fine. Any ideas?
Old Jun 23, 2018 | 04:37 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Read the actual data for throttle %, that will tell you if the ECU is getting the correct signal from the APP switch.
Typically however when you have throttle LAG like you're saying there is a large vacuum leak and the ECU is scrambling to fix A/F that's out of whack and not generating power properly.
asherwin
V36 Engine, Exhaust, Drivetrain & FI
Oct 3, 2010 10:44 PM
benu4yooh
Dec 6, 2007 03:47 AM
logik05se
May 3, 2007 04:52 PM
slimjim
Sep 5, 2006 11:38 AM
