Cylinder 3 Misfire 04 G35
Old Jul 12, 2018 | 10:56 AM
vcoak's Avatar
I'm experiencing a Cylinder 3 misfire. I've changed out all of the plugs and coilpacks and this issue still hasn't gone away. I also cleaned the MAF as well as the air filter also. Still throwing the code. Has anyone else experienced this, and if you have how did you resolve the issue???
Old Jul 12, 2018 | 04:42 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Remove the fuel pump relay from the IPDM, crank motor and run until it stalls, remove the suspect spark plug, plug it back into the coil pack and hold it with a leather gloved hand about 1/4" away (measured from teh ground strap of the spark plug) from the intake manifold while someone else cranks the motor and you visually observe spark. Compare with a second spark plug, compare against a different coil pack. If there is a weak spark or NO SPARK you will see the difference when compared to another cylinder. You might have a damaged wire, wiring harness, another bad coil pack, etc.
Old Jul 12, 2018 | 08:11 PM
coffeysm's Avatar
Might want to check #3 fuel injector as well, while you are messing around in that area.
garry101
29
Feb 10, 2023 01:23 PM
IVAN S.
Oct 4, 2020 10:34 AM
Cesar023r
12
Jan 10, 2013 03:36 PM
Cesar023r
Jan 7, 2013 12:56 PM
aero
Forced Induction
12
Apr 18, 2008 11:42 PM
