Engine cover paint
Old May 13, 2003 | 12:55 PM
slinkyboi5's Avatar
Engine cover paint
Can anyone point me to a source of paint that will adhere to the engine cover plastic on the sedan and be heat safe? I'd like to paint my engine cover similar to the coupe.
Old May 13, 2003 | 04:36 PM
Rumble's Avatar
Re: Engine cover paint
I bought some paint from Candian Tire (I'm in Toronto), but you can probably get this paint from any Pep Boys type or hardware store. Just look for a label that is High Heat. Mine says "High Heat Manifold Paint" and is rated to 648 degrees Celsius (1200 degrees Fahrenheit). Good luck.
It's still a G thang!!
Old May 13, 2003 | 07:09 PM
slinkyboi5's Avatar
I found some that was 500 degree and some that was 1200 degree. I asked the guy if it was safe for plastic and he said that since it was enamel, it would likely eat at the plastic. Do you know what type of paint you got...even a brand name would be cool.
Old May 13, 2003 | 09:32 PM
RamboRami's Avatar
G35driver.com Moderator
probably ceramic based paint
<font color=green>-Leblau Timmaw</font color=green>
Old May 15, 2003 | 01:32 AM
NismoV35's Avatar
From: Los Angeles, National Socialist Democratic Republic of Facistfornia
Use the same type they paint the car with. Just make sure you sand the plastic cover with 400 grit wet or dry sand paper. And wash the cover with some Dawn dish soap to get off all the plastic residue and grease. This way the Paint will adhere real good to the plastic.......
jsimonk
Dec 22, 2023 03:49 PM
redonblack35
Accessories
19
Feb 13, 2016 11:19 AM
derres
Aug 28, 2015 03:27 PM
joedaddy1
Jul 28, 2015 02:58 PM
newg37
Jul 26, 2015 09:32 AM
