Anyone using Z1 Motorsports Urethane Motor Mounts
Old Jan 2, 2019 | 03:17 PM
Albanian122's Avatar
Looking to swap out the OEM motor mounts when installing new momentum headers? anyone currently using these, how is the vibration and noise in the Cabin, * I have an automatic.
I'm currently using a Motordyne Exhaust and Test Pipes so curious if the vibration will be noticeable when at Idle,
Old Jan 2, 2019 | 03:33 PM
Urbanengineer's Avatar
Someone did those and the trans mount. Apparently the engine ones weren't horrible but the trans mount in urethane was too much.
Old Jan 2, 2019 | 03:45 PM
yea I don’t think I’m doing the trans mounts, thinking of just the motor mounts but going back and forth if I should do the OEM or z1
Old Jan 2, 2019 | 05:41 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
They definitely add a bit of vibration and harshness but I don't think it feels TOO harsh, they feel amazing on a 6MT and I have no regrets about using them. I have engine and transmission.
Old Jan 2, 2019 | 06:28 PM
MooseLucifer's Avatar
5 Year Member
blk
You might also look into Brett Dempsey Engineering (BDE) engine mounts - they seem pretty cool but I have not tried them myself.
I actually worked with the guy for a while before he left to run BDE full time - incredibly smart, nicest guy you'll ever meet plus he has a stable full of Z cars haha
Old Jan 2, 2019 | 06:39 PM
i looked into BDE concept a performance sells them same price as Z1 not much information on anyone running them so it’s hard to get a good idea of how they are on the car
Old Jan 2, 2019 | 06:40 PM
i daily the car and its its an Auto , I found OEM brand new for 160 and z1 is 200. So I’m trying to make the right call on which to get
Old Jan 2, 2019 | 08:37 PM
herrschaft's Avatar
If you don't mind the possibility of added vibration than get them. I'm still on stock mounts but I'll be getting a set of these poly ones soon.
Old Jan 2, 2019 | 09:41 PM
cswlightning's Avatar
On an AUTO, I would definitely stick with rubbers. The biggest advantages are shifter feel and clutch engagement, and the auto's throttle transition is already smoothed out by the torque converter. The extra vibes are pretty minimal after a 500 mile break in period, on my car nothing rattles at idle after I cleaned out my throttle body to keep the revs from dropping. I do get a slight vibration at 2000 RPM but I'm pretty sure that's just the mounts magnifying a separate issue.
IMO (for 6MTs)
If you're a street driver who doesn't beat on their car often, get the rubbers.
If this will be used as a track car at any point or you like to speed, the polys are worth it for both the added durability and improved shifting and throttle transition feel.
I'm happy I installed mine!
Old Jan 2, 2019 | 10:36 PM
IMO (for 6MTs)
rubber meaning OEM or the z1
Old Jan 4, 2019 | 08:31 PM
herrschaft's Avatar
rubber = OEM
Old Jan 7, 2019 | 07:25 PM
Scottwax's Avatar
5 Year Member
6 speed G35 sedan
I've got an Innovative urethane side mount on my Accord (motor mounts are a real sore spot on 7th gen Accords and 3rd gen TL's) and if there was an increase in vibration, I didn't notice it. Ran solid engine mounts on my Chevelle, engine was balanced so that helped but vibration was less than expected. What might work well on a G35 if vibration is a concern is going with a urethane mount on the passenger side since that's the side that torques up when you get on it and rubber on the driver's side.
07redcoupe
Sep 1, 2017 10:54 AM
Labeatit
Archived Sales
21
Feb 8, 2008 02:17 PM
shadyg
Dec 20, 2004 08:34 PM
