"Boreing out the engine"
Old Mar 7, 2005 | 04:04 PM
mbq62's Avatar
Sorry if I spelled it wrong. What are the benefits of this? What is it for? N/A or FI? Who would be qualified to do such a job? Thanks.
Old Mar 8, 2005 | 01:31 AM
Jahan's Avatar
I'll bite . . . Boring the engine means to increase the diameter of the cylinder to increase displacement. More displacement = more power. It's good for NA apps, but FI can take even better advantage of the extra cubes.
Since it requires a complete engine teardown and assembly, as well as tightly controlled maching processes, I'd only trust a very specialized shop to do this type of work on ANY modern engine. Also, this is NOT a cheap process . . . besides the labor, you'll also need new pistons to fit the oversized cylinders. Most people who go through this trouble have otherwise heavily modified their engines.
Old Mar 8, 2005 | 02:06 AM
RussB's Avatar
AEBS has a 4.5L (i think it's 4.5) bored and stroked block with forged internals. if i ever decide to sink that large of a chunk of change into this car, that's the route i'm going to go.
Old Mar 8, 2005 | 08:17 AM
mbq62's Avatar
Are there any negative effects? How much would something like this cost? Wouldn't this be a good start to having a strong N/A engine?
Old Mar 8, 2005 | 08:37 AM
pdjafari's Avatar
The totals including parts and labor id say would run above $10k, thats including forged internals w/ larger pistons etc...
Old Mar 8, 2005 | 08:58 AM
neffster's Avatar
Actually I don't think AEBS has a complete package yet. They're still missing one major component (at least they were as of last month).
For some interesting reading on the 4.3L AEBS STROKER KIT, click on MR. SMILEY FACE...
You'll have to register for my350z.com if you haven't already.
Old Mar 8, 2005 | 02:48 PM
mbq62's Avatar
Does anyone have a link to AEBS kit?
Old Mar 8, 2005 | 02:51 PM
mbq62's Avatar
pdjafari - did you do all the mods yourself or did you have someone help you? Where did you buy the Motordyne 3/8'' plenum spacer, and get it installed? And how has the performance changed from it?
Old Mar 8, 2005 | 02:53 PM
pdjafari's Avatar
i dont know of a 'link' so to speak but I do believe there are some vendors who sell the kits...lemme run a search real quick...
http://www.i-m-racing.com/aevqstkitg35.html
thats one vendor...not sure if this is what you are looking for...maybe your looking for the actual manufacturer site?? not sure if they have one...
Old Mar 8, 2005 | 02:56 PM
pdjafari's Avatar
mbq62,
I have performed all the mods thus far myself and will continue to do so. The only one i am hesitant on doing myself is the UR pulley's. Only reason is I once replaced a water pump on my 86 cutlass. This involved similar work that the pulley's removal also requires. I remember it took me around 4 hrs or so to remove, replace the water pump. Now the pulley's should be easier, however I am not sure if they involve removal of the fan. This I remember took the longest amount of time for me. Other installs I have done are: Samco hoses, plenum spacer, Y pipe, Ztube/pop charger, grounding kit, painted battery cover's, gialla, eyelids, fogs, clearance...
Old Mar 8, 2005 | 02:58 PM
pdjafari's Avatar
O, BTW I can tell you of all the mods I have done, the best bang for the buck and the one that I have so called 'felt' the most is the Plenum spacer. Next would be the Y pipe...z/tube pop charger was/is negligible as was grounding kit.
Old Mar 10, 2005 | 05:43 PM
mbq62's Avatar
Which vendor did you purchase the Plenum spacer from?
Diode Dynamics
Accessories-Vendor
39
Nov 30, 2021 02:28 PM
Jiggerjuice
Dec 6, 2015 10:29 PM
Visionnn
Oct 3, 2015 05:16 AM
w4kj4k
Oct 2, 2015 07:57 PM
MooseLucifer
Sep 1, 2015 05:11 PM
