Swap a new engine and won’t start
Old Aug 10, 2019 | 01:31 PM
Josh Lee's Avatar
Blew my motor in my g35 pulled it and and put a vq35de rev up in it’s the same motor and it won’t start it will turn over but it will not start are any ideas or anybody in the winsaid nc area that are willing to help
Old Aug 10, 2019 | 07:47 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Something probably isn't hooked up right, check for spark, pull the plugs after a few attempts and see if they're wet (fuel check) my guess is they're not firing. Is your NATS/IVIS security indicator on the dash SOLID RED when you are cranking the motor?
It's also possible the new motor has a bad crank sensor, does the tach move when you are cranking or no?
Also possible the new motor has a bad cam sensor.
Did you swap over your existing flex plate (5AT) or flywheel (6MT) and if so did you align the dowel pin correctly? If it's not in properly alignment it definitely will not start.
Old Aug 11, 2019 | 02:15 PM
Scottwax's Avatar
5 Year Member
6 speed G35 sedan
Did a 455 swap into a '77 Cutlass years ago. Same deal, except absolutely nothing. No lights, no start, like the car was completely dead. Next morning I get up under it to see what I missed. One single wire hanging down by the starter. Hooked it up, car started immediately. It's almost always something minor like that.
laratta
14
May 20, 2019 10:30 PM
ZippyDoozy
Aug 17, 2017 11:32 PM
ZippyDoozy
Aug 15, 2017 05:42 PM
RemmyZero
Aug 22, 2015 11:38 AM
ChrisKG35
Sep 8, 2013 07:11 PM
