No crank, no start 2005 G35 coupe
Old Sep 16, 2020 | 04:45 PM
Rainy's Avatar
2005 G35 Coupe loaded but bone stock!
Really need some help on this one guys!!!
2005 G35 coupe
I've been having this issue on and off for a month. The car will be totally fine, ill park it, then all the sudden it wont start, or even crank over. I literally turn the key over and over again, and it will eventually crank, and start. Sometimes its 20 turns, sometimes it wont start for an hour or at all. It seems to do it after I take a drive. Ill drive for a bit, run in somewhere, come out and it wont start. Every time I come out in the morning it starts every time.
Battery is good, and I switched the ignition and starter relays out for good ones (used the headlight relays i knew were working) and nothing changed.
Is this just a bad starter or something else? It's just very strange it is doing it intermittently. I figured if it was the starter, it would be bad for good.
Any help is greatly appreciated
Old Sep 16, 2020 | 05:26 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Does it ONLY do this when the engine is hot? When the solenoid fails it can commonly cause a "fail to start when hot" condition.
If so then yes, failing starter solenoid, new starter will fix.
Old Sep 16, 2020 | 05:39 PM
Rainy's Avatar
It sure seems like it, maybe thats why it started today after sitting in the parking lot for over an hour changing relays etc, it could have cooled down?
When I come out and start the car in the morning its fine. Also after I take 30 minute freeway trips, it will do it about half the time, maybe 80mph air is cooling the starter enough.
Old Sep 17, 2020 | 10:12 AM
andrewl_v35's Avatar
04.5 G35 Sedan 5AT
Sounds like starter is failing to me.
Its mounted near the cataysts, so I'd imagine it gets rather warm.
Old Sep 17, 2020 | 12:07 PM
cleric670's Avatar
BANNED!!!
Yep that sounds EXACTLY like a failing starter solenoid. They get heat soaked and you get hot start failure, it won't even make that loud CLICK sound, just NOTHING when you turn the key.
Once it cools down it starts.
Old Sep 18, 2020 | 08:28 AM
Rainy's Avatar
As always, you're the man Cleric 😎 Ill order a starter. Ive been keeping the car on if I have to go out. Going to start driving the Z28 till its fixed.
Thanks man, Ill post back after the new starter goes in and let you know if its fixed.
Old Sep 18, 2020 | 08:29 AM
Rainy's Avatar
Thanks man
RedG35Az
May 14, 2014 10:03 PM
mentommy
May 12, 2012 11:56 PM
tcpombomb
Dec 18, 2011 06:41 PM
ModMe
Jan 27, 2007 12:24 PM
