SMH not sure what to do next with P0300
Old Nov 23, 2020 | 12:39 PM
cshaw_tx's Avatar
2005 G35 Coupe
Hey guys and gals, not sure what to do next. I got a blinking SES light with the P0300 code and after reading online for hours I took it to a shop to get all spark plugs, all 6 coil pack, and fuel injectors replaced.
The check engine light still comes on and blinks with the P0300.
What should I do next? Sell it?
Old Nov 24, 2020 | 01:23 PM
andrewl_v35's Avatar
04.5 G35 Sedan 5AT
I'd try cleaning the mass airflow sensor & check for vacuum leaks. The intake couplers seem prone to cracking in my experience.
Old Nov 25, 2020 | 10:18 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Did this problem just randomly pop up or did you buy the car with the SES light on?
Fuel pressure test, you will need a sandwich adapter like the one sold by Z1 Motorsports.
Compression test.
Old Nov 26, 2020 | 01:03 PM
Scottwax's Avatar
5 Year Member
6 speed G35 sedan
Sounds like the shop didn't follow the proper diagnostic procedures before throwing parts at it. Have you gone back there yet?
Old Nov 26, 2020 | 11:52 PM
Jyounya's Avatar
Ivory Pearl G35 Coupe
(Highjack) I've been having the same problem with P0300 for almost two years. I'm at 205k miles (Yikes). Mods and replacements:
  • NGK Iridium Spark Plugs (replaced)
  • Fuel Pump/Sending Unit (replaced)
  • Original Fuel Injectors (cleaned)
  • Original Coil Packs (with F mark) (Checked, no swelling)
  • Z1 Plenum Spacer (mod)
  • Z1 High Flow Cats (mod)
  • Z1 Fuel Pressure Adapter w/Pressure Meter (mod)
  • Z-Tube Intake (mod)
  • K&N Air Filter (mod)
  • 350z Y-pipe (mod)
  • Z1 Aluminum Coolant Bleeder (mod)
  • Koyo Aluminum Radiator (mod)
Sometimes, rarely, the light goes off. Often times, it's when my oil starts to get low. Sounds like like a Valve Cover Gasket, right? However, when I check the spark plug wells, they're clean. (I'm not ready to drop $400 on the VC gasket kit)
ok, pulled spark plugs and saw this in cylinder 6 spark plug well.
Old Dec 15, 2020 | 11:30 PM
3rick35c's Avatar
Under Construction
You might want to check if there is a short in the main wire harness and see if there are any shorts in the ECU. I resolved my issue by finding a short in both the wire harness and ECU.
Near323
Aug 17, 2018 01:26 PM
hockeyguy215
Dec 13, 2016 09:07 PM
bmwm3nick
Dec 29, 2008 11:04 PM
lenZG35
Nov 18, 2007 11:28 PM
IvoryGT-V
Forced Induction
Jul 18, 2006 06:48 PM
