Service engine soon light came on help.!
so I changed my spark plugs today along with my oil and after I put everything back together and turned the car on the service engine so light came on. It wasn’t on before the car runs and drives just a little scared to drive it with the light on. Plugged it in the computer and I was told my 3 spark plug is the issue. Not sure which on the would be bit I checked all the plugs and can’t find the issue the light eventually went off but when I plug it to the computer that code still shows up. Any help ?
What exact code showed up? Bank one is the passenger side of the motor and has cylinders 1, 3, and 5 respectively from front to back. Bank 2 are cylinders 2, 4, 6.
no i didn’t I unplugged it today and gonna let it sit unplugged for a while then plug it back in hope that work
i unplugedd the batter negative side I’ll check the code again once I plug it back in not to sure what code pops up thank the so the 3 one would be on the passenger side in the middle
Mark7
Dec 21, 2019 06:22 PM
AJsFirst05G35
DFW G35 Owners Club
Aug 27, 2011 11:51 PM
gq916
Jan 1, 2011 11:36 PM
