Help, VDC OFF light, SLIP light, and SERVICE ENGINE SOON light all on
Old Jun 16, 2014 | 06:38 PM
Mark7's Avatar
Hi guys, I need help, driving home normal speed 50 Kph, all of a sudden VDC OFF light, SLIP light, and the SERVICE ENGINE SOON light comes on and no power. Almost like the Valet Key was being used.
2004 G35 6mt coupe 103,000 kms
I pulled over and shut the car off, restart, same lights still on.
Seemed to get a bit of power in first gear, but nothing in 2nd, 3rd, etc.
I disconnected the negative battery cable and the VDC and Slip went out, but Service light is still on.
It seems like a code to me, but live in the country and not close to a diagnosis machine
Wasn't driven in rain, seem to be running fine up to this moment.
Any ideas, please?
Thanks,
Mark7
Old Jun 16, 2014 | 07:27 PM
Urbanengineer's Avatar
Cam positioning sensors. It comes out of nowhere.
Old Jun 16, 2014 | 07:58 PM
Mark7's Avatar
Thanks brother, this sucks big time, I kinda noticed it running a bit richer then usual, but the fuel, premium, is a joke right now, nobody uses it so it is less then optimum grade, at a 1.40 a liter.
Didn't notice any performance loss but like you said, it comes out of nowhere. Still have a Dodge truck that used to leave me stranded in the car wash, crank sensor.
Thanks,
Mark7
Old Aug 28, 2014 | 09:43 PM
PearlPereZ's Avatar
Thanks,
Mark7
Same thing happened to me. I had a bad camshaft position sensor only one bad, but replaced both. Till this day no problems no check engine lights.
Old Sep 23, 2014 | 02:41 AM
dmertz92's Avatar
My 07 g35 service engine vdc and slip light all came on today. the car has alittle smokey exhaust and is running as if it has a misfire... HELP please i dont know what it could be .. and i dont want the dealership taking me for a ride for my money
Old Sep 23, 2014 | 03:54 AM
scottvt's Avatar
Why not try cam position sensors as mentioned here?
Old Dec 20, 2019 | 03:16 AM
kenny etenne's Avatar
2007 g35 sedan
having this same issue anyone find a solution?
Old Dec 20, 2019 | 05:18 AM
Scorpi0's Avatar
scan your car for codes
Old Dec 20, 2019 | 05:32 AM
2007 g35 sedan
Only got 2 codes p0300 (random misfire) and p0081(intake valve control solenoid circuit bank 2).
Car will run fine then start misfiring when the slip and vdc light come on. If i hold revs at 3k rpm check engine light comes on and flashes.
Old Dec 20, 2019 | 10:38 AM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Fix the random misfire first, pull, inspect, replace all your spark plugs. Inspect coil packs for blistering on the epoxy resin, scorching of the well tube, corrosion on the little contact spring inside the well tube. Also inspect the valve cover wells for any oil in the tube shafts.
Your bank 2 cam solenoid is probably messed up, unplug and inspect the harness for any corrosion or oil contamination.
Have you checked oil level lately?
Old Dec 20, 2019 | 10:58 AM
2007 g35 sedan
ill mess with it later on today. Oil level is half between add and full on dipstick. Where is the cam solenoid located?
Old Dec 21, 2019 | 05:51 PM
cleric670's Avatar
BANNED!!!
Top of the engine right in front of the valve covers.
Old Dec 21, 2019 | 05:57 PM
2007 g35 sedan
Had a cylinder 4 misfire (replaced coil). And oil was 1 quart low.erased codes seems fine so far.
Old Dec 21, 2019 | 06:22 PM
cleric670's Avatar
BANNED!!!
Awesome, glad it's all sorted out.
Mrs.Valdez23
May 7, 2015 09:40 AM
bendigi
Mar 20, 2015 12:44 AM
Reckless_405
Jan 28, 2015 06:39 AM
1star2
Feb 26, 2011 05:35 PM
G35ftw
Sep 12, 2006 10:52 AM
