Slip Light, Vdc Off Light, Service Engine Soon Light Off & On
Old Jan 28, 2015 | 06:39 AM
Reckless_405's Avatar
Trying Not To Lose My Patience Here... But With A 2003 Coupe Sometimes That's A Little Difficult. I've Been Through The VDC, Slip, & SES Lights All Coming On & Whenever I Would Accelerate Hard It Would Sometimes Die Unless I Kept The Gas Pedal Massed & Then About 3 Seconds Later My Car Would Hook Up & I Would Be On My Way... I Solved That Problem By Flashing The ECU & Haven't Delt With It Since. However.....
Now When I Accelerate Hard (& No I'm Not A Complete Idiot That Just Floors It On The Road, I Take It To A Track To Do All Of My "Shananegians") (Just Before 6500 Shifting) My Car Almost Seems Like The Battery Pulses To My Car Causing It To Decelerate & The RPM's Gauge To Drop & Then Rise Again, My Speedometer Does The Same. The VDC, SES, & Slip lights All Flash On & Then Quickly Flash Off... After My Car Loses Power For About 1 Second & Randomly Hooks Back Up & I'm On My Way... I've Seen The Brake Fluid Remedy, The Sensor Problems, The Different Wheel Size, But This Is Something I Have Yet To Read About & I Need Some Solution...
Mry
Mar 3, 2023 01:03 AM
SiMpLyMoDiFiEd
The FX-Spot
Dec 2, 2021 04:35 PM
Luisgalvan33
Jul 19, 2018 08:16 PM
MsFitFern
Aug 9, 2015 02:58 PM
igking
Jul 19, 2015 01:12 AM
