Transmission help !
Old May 29, 2021 | 09:51 PM
Skkywoe's Avatar
Coupe
Transmission help ! VIDEO ADDED
I don’t know if this is the right spot to post this, guide meto the right spot if need be !
2005 AT coupe. I was having problems with my car starting and I got a code for the camshaft sensor bank 1. I swapped that out and that hasn’t been a problem but now my transmission is slipping but no code. It’ll get to about the two on the rpm before driving. Last year I replaced the torque clutch converter so I don’t think it could be that.
( btw I ordered new strouts, I know about the noise)
Old May 30, 2021 | 01:00 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Check your fluid level on the tranny.
Old May 30, 2021 | 02:34 PM
Skkywoe's Avatar
Coupe
I’ll post a picture of the readings, because I might be reading it wrong. It looked fine to me
Old May 30, 2021 | 07:05 PM
cleric670's Avatar
BANNED!!!
As long as you check it with the engine running, go through P, R, D, N, 2, 1, then back up through the gears, pausing for about 1 second on each gear. Then leave the engine running, pull the tranny dipstick, wipe, put the dipstick back in and do this 5-6 or more times to clear fluid off the well, THEN take a reading.
If you take the reading with the engine stopped you're not getting a real fluid level reading, ideally you would go for a short drive to warm up the tranny but it doesn't sound like you can do this right now.
If the fluid level is within the dashes on the dipstick then you probably just have a smoked transmission that's slipping and needs a rebuild.
Old May 31, 2021 | 01:30 PM
Skkywoe's Avatar
Coupe
So It drives and has been driving tbh, due to me only having one car and the military not giving a **** until it can’t be driven anymore I have to get to work. I’m trying to post a video but it won’t upload
Old May 31, 2021 | 08:38 PM
cleric670's Avatar
BANNED!!!
Put the video on youtube, then put the link here and it will automatically embed the video.
aalqaedi
Jun 22, 2024 10:01 PM
khitman18
Oct 20, 2017 10:25 AM
Ricardo_Galeno
Feb 15, 2016 07:30 PM
RODO0409
Jun 24, 2010 11:45 AM
