G37 Coupe V36 2008+ Discussion about the G37 Coupe
Code P0051
Old Jan 15, 2020 | 07:20 AM
aalqaedi's Avatar
Post Code P0051
Hi guys,
I’m having a code P0051. I did change the O2 sensors but no use. Any help is highly appropriated
Thanks hugs.
Old Jan 15, 2020 | 02:30 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
EXACTLY which sensor did you replace, there's 4 of them. That code is for the bank2 sensor1, that's the upstream one mounted in the header on the left side of the car (driver side for a left-hand-drive model).
Old Jan 16, 2020 | 06:43 AM
aalqaedi's Avatar
Hi Cleric,
Yes I did change the sensor bank2 sensor1 and the problem is the same. I will check if the new sensor is Ok or busted.....
wish me luck.....
thanks for your replay.
Old Jun 22, 2024 | 10:01 PM
sirjeffers29's Avatar
M/T, Sport Suspension
Originally Posted by aalqaedi
Hi Cleric,
wish me luck.....
did you ever figure out what was happening? I’m having the same problem. The only code I’m getting is P0051. I replaced the bank two sensor one A/F sensor with a new denso sensor (it has the wideband six pin air fuel sensor not the 4 pin)on my 2003 g35 I checked the fuse and it was good starting to think it’s a problem in the hardness
lgbent
Aug 14, 2020 06:57 PM
Serna
Jan 6, 2020 06:07 PM
jonnylaw
Mar 25, 2019 05:37 AM
VQSTONE
Dec 9, 2013 09:34 AM
officerdbag
Feb 14, 2010 10:54 PM
