Issues with code p0037
Old May 29, 2017 | 10:02 PM
lgbent's Avatar
I recently threw a p0037 code which I took to my mechanic and he change the o2 sensor but it still comes back. I can clear it and drive for awhile then it throws a code again. The sensor is not form and could this be the problem or something else , all the wiring checks out ok. Looking for ideas before I take it to the dealership.
Thanks
Old May 30, 2017 | 12:56 PM
LoSt180's Avatar
P0037 is sensor #2 (the rear one) bank 1 (right/passenger's side) heater circuit low. Possible causes are: harness or connectors (the heated oxygen sensor 2 heater circuit is open or shorted), or heated oxygen sensor 2 heater.
Either replace the sensor, and/or double check wiring. The Rear O2 sensors connect to the bottom of the trans, so they're kind of exposed and can get damaged fairly easily if bottoming out of something or road debris. If you have an OBD2 dongle, you can use an app on your phone to monitor the heater circuit and verify if it's turning off/on like it should. Instructions are the FSM.
Old May 30, 2017 | 11:08 PM
lgbent's Avatar
I had new sensor replaced but still throws code, I weird thing is once the code is cleared I can drive and code will not show up. Once I stop car and let it sit ,it will throw same code after a couple minutes. Any ideas why or should I go to the dealership because my mechanic can't figure it out.
Thanks
Old May 31, 2017 | 03:15 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
You're sure he's replacing the correct sensor and not one of the other 3 ?
Old May 31, 2017 | 06:52 PM
LoSt180's Avatar
Make sure the connector is clean and has the rubber seal to keep moisture out. If it's been replaced, then it sounds more like wiring.
Many codes take multiple trips before flagging the check engine light. So the light not coming on right away is normal.
Old Aug 14, 2020 | 06:57 PM
reap's Avatar
g37 test pipe rest stock awaiting coilovers and nee wheel/rims next!
Thanks
i dont understand why You get a car like this and absolutely don't know how to work on a car at all. It totally blows me bruh
El_Donks
Intake & Exhaust
Mar 6, 2022 12:22 PM
Serna
Jan 6, 2020 06:07 PM
jonnylaw
Mar 25, 2019 05:37 AM
LowUFO
Apr 5, 2011 12:37 AM
officerdbag
Feb 14, 2010 10:54 PM
