Engine management slip vdc lights on
Old Sep 15, 2021 | 10:11 AM
andy350gtuk's Avatar
Change coil packs and plugs but no misfire po350 code
Old Sep 17, 2021 | 11:27 AM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Did you have this code BEFORE changing that stuff?
Old Sep 18, 2021 | 10:00 AM
Yes
Old Sep 18, 2021 | 10:04 AM
I had the misfire changed the coil packs and spark plugs and the code is still There
Old Sep 18, 2021 | 11:10 AM
cleric670's Avatar
BANNED!!!
Clear the code and see if it comes back, might just be held over from the previous malfunction but was never actually cleared.
Old Sep 18, 2021 | 11:12 AM
I have comes back on
Old Sep 18, 2021 | 11:20 AM
cleric670's Avatar
BANNED!!!
In that case I would start ringing all those wires out back to the ECM and IPDM to verify it's not just degraded wiring.
Steps are in the FSM section EC - Engine Controls, look up codes P0300 - P0306 for the wiring.
There is also an ignition condenser that you should replace, it's a very inexpensive part and capacitors do wear out.
Also check the grounds, particularly the engine-chassis ground on the passenger/right side of the timing chain cover that goes to the chassis below the coolant reservoir.
https://www.nicoclub.com/infiniti-service-manuals
kotched
Sep 23, 2010 01:26 AM
snakes1021
May 29, 2010 04:16 AM
Dreampkt_GDG
DFW G35 Owners Club
32
Jan 18, 2010 01:12 PM
c35
Jun 28, 2009 04:42 PM
