service engine vdc and slip lights worn go off
Old Jun 20, 2009 | 01:18 AM
snakes1021's Avatar
car is hesitant to start and the vdc off slip and service engine soon light will not go off. tried to reset the ecu and the ses light would not blink.
the car was hesitant to start this evening drove home playing around with a friend on the highway with the vdc off now i get those 3 lights and vdc and service warnings on my nav screen any ideas i read a few posts forma while back with the same issue but no answers. ill keep looking maybe it will be fine tomorrow after a good nights rest.
Old Jun 20, 2009 | 11:38 AM
snakes1021's Avatar
disconnected the battery for a few no more lights. yippie. then i waxed and washed the g
Old May 26, 2010 | 07:42 PM
paquette173's Avatar
i got that same exacte problem as you yesterday, disconnected my batterie 10 min. everything went away my car started well, but then again today same probleme came back!!
Old May 26, 2010 | 07:57 PM
snakes1021's Avatar
mine was the cam position sensor i wrote a DIY to replace them both if you need it. checked the codes at auto zone. for free the bought parts from my boy at the stealership an did it myself
Old May 26, 2010 | 10:44 PM
ok this is weird, i went to get my friends scanner, went for a ride with the car and the SES,VDC,slip never got on. The probleme is only there when it wants to ? did that happen to you ? Mabye its the heat we got here for the last 3 days and the ac was running alot.
Old May 28, 2010 | 08:26 PM
snakes1021's Avatar
mine went off for a day or 2 here and there then when it stayed on i checked it reset it a few time, no joy and that was that.
Old May 28, 2010 | 08:27 PM
snakes1021's Avatar
when it come on find an autozone and use their scanner on the spot.
Old May 29, 2010 | 04:16 AM
geeder's Avatar
your power steering fluid is low i had the same problem
Mry
Mar 3, 2023 01:03 AM
SiMpLyMoDiFiEd
The FX-Spot
Dec 2, 2021 04:35 PM
Wayne9011
Aug 17, 2015 01:24 AM
Wayne9011
Jul 27, 2015 11:25 AM
newg37
Jul 26, 2015 09:32 AM
