04 g coupe u1000
Old Feb 7, 2022 | 03:10 PM
CoupeQ78's Avatar
g35
04 g coupe u1000
Looking for any help and direction . 2004 g35 At when I first got the car it was throwing a p0300 & p0306 code & was a hard start . Once I started changing the coils & spark plugs I saw that cylinder #4 & #6 plug wires were swapped so I fixed those getting rid of both p0300 & p0306 codes . Now I’m getting a U1000 code & a pending Cylinder 1 misfire . Cluster isn’t showing what gear I’m in & AT check light in staying on . I’ve checked all grounds but I have not checked injectors . Ipdm box has been replaced as well & no corrosion on ECU or ipdm box connectors . Battery connections are good as well . Any help or anybody had these issues before ? If it’s a short to ground could I run a ground wire from the battery to the ECU & tcm ? Any help wanted !
File Type: mov
Old Feb 8, 2022 | 10:31 AM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Is it an internal or external TCM. I would start by inspecting the harnesses on the transmission to see if it's something obvious.
Old Feb 8, 2022 | 12:15 PM
CoupeQ78's Avatar
g35
I’m on the way now to check can you tell me what it would look like besides the ECU if on the passenger side kick panel ?
Old Feb 11, 2022 | 08:29 AM
cleric670's Avatar
BANNED!!!
Checking that kick panel is quick but you can also look at the left side of the transmission and see if it's got 3 separate harnesses mounted to the side of the tranny with about a foot of wire going into the transmission, or a single large harness plug right where the wires go into the transmission.
3 separate is the external, single large harness is the internal.
I think you should drive the vehicle down somewhere that can OBD2 scan for transmission codes and see what it's throwing, that will save a lot time guessing about what the issue is.
dacrew4009
Jun 24, 2023 01:00 PM
Mr.Davis32
Feb 4, 2021 07:36 PM
Vqalexisz
Apr 5, 2016 08:49 PM
Vqalexisz
Oct 14, 2015 12:48 AM
Stiker181
Aug 2, 2011 07:12 PM
