overheating again
Old Jun 12, 2022 | 06:26 PM
b73's Avatar
b73
Auto,up rev
Angry overheating again
Ok im not understanding what is going on, was driving my 05 g35 cpe when all of a sudden it went rogue and overheated and she started bucking big time and wouldnt go over 35....wtf ...so the task at hand was to see what happened i limped it home for 3 miles
1. fans still work
2. lower hose was cold
3. upper hose big time swelled up
so i did what anybody would do.....bought water pump and thermostat...
replaced both at the same time and guess what??? the dam thing still overheated....wthell
i was mad and walked away so now what?
Old Jun 13, 2022 | 05:57 AM
telcoman's Avatar
Veteran: Army
1. fans still work
Have you carefully followed the troubleshooting steps in the FSM?
https://www.nicoclub.com/service-man...F2005%2Fco.pdf
See page CO-6
Good luck
Old Jun 13, 2022 | 07:24 AM
b73's Avatar
b73
Auto,up rev
i have refilled the coolant like it says, open the heater core bleed port while filling and had the back of the car lower while filling put the heat on high.... i can only think there might be a air buble still in there but im going to try and run again today to see if now that it cooled down that maybe it left, ..while it was runnig it filled the overflow bottle all the way and now its empty.......so we will see what happens i dont know what else to do, maybe just leave cap off and make sure it flows
Old Jun 13, 2022 | 01:56 PM
telcoman's Avatar
Veteran: Army
Did you use the recommended Nissan coolant?
i i dont know what else to do, maybe just leave cap off and make sure it flows
Did you replace the radiator cap?
Have you completed a pressure test?
You may also need to perform a compression test?
Good luck
Old Jun 17, 2022 | 10:37 AM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Are you making sure to turn the heater on MAX HOT with the fan on MAX during the initial drive to burp the heater core? If not then the heater core valve is still shut and you will NEVER get the bubble out.
Here's a thread I made on refilling the coolant system.
https://g35driver.com/forums/engine-...ml#post7211802
Old Jun 19, 2022 | 04:02 PM
b73's Avatar
b73
Auto,up rev
another update cleric670
ok after 2 days of coolant pressure test....it only lost 2lbs and it went from 89 yesterday to 54 last night so im not worried ......so i took the car out for a test drive, the first 3 miles and i had heat out the vents woohoo temp gauge stayed below halfway AWESOME !!! im excited now and i kept driving another 3 miles and saw temp gauge climb OH SHOOT ....lost heat to vents and gauge kept climbing so i reverted to the emergency brake stop to push fluid and force air out, well that didnt work so i headed for home by the time i went the 5 miles to home it was redlined, i am done trying to figure this out now, is there anybody within an hour or so even two hours from rockingham raleigh aberdeen NC that would like a shot at fixing this....??? i really dont want to go to dealer HELP!!!
Old Jun 19, 2022 | 10:09 PM
cleric670's Avatar
BANNED!!!
It displaces a lot of coolant when it finally pulls the bubble out of the heater core, it will suck the reservoir completely dry. Thus why it's usually a SHORT drive so you can quickly get back to shop to refill.
What probably happened is the bubble popped but then you were just low on coolant. Check radiator and reservoir coolant levels.
lemmy999
Mar 9, 2018 08:03 AM
Turbopseidon
Jul 10, 2017 11:34 PM
stl.rbizy
Feb 7, 2015 01:55 PM
biggerandbetter
Jun 9, 2011 09:00 AM
wannascooby
Mar 3, 2010 06:19 AM
