Rpm goes down and up under load
[size=16px]Hey everyone I have a g35 2004 automatic sometimes after I press the gas padal the [/size]rpm[size=16px] suddenly drops then returns to where it normal would be.. It was happening alot then I changed the throttle body and the system occurs less but still happen... what could it be? Should I clean the maf sensor and check for vacuum leaks...[/size]
[size=16px]and the drop of [/size]rpm[size=16px] only happens when i am in drive never in park[/size]
and I change the crank sensor a few years ago
I just change my crankshaft position sensor but the rpm still does the same thing but it's happening less and not as drustic the rpm drop... what else can i do
https://youtube.com/shorts/Pam9vkzVMKs?feature=share
jdmeg21
Apr 4, 2011 09:27 AM
