G35 Overheating Strange Symptoms
Old Dec 9, 2024 | 05:02 PM
_AquaBullit_'s Avatar
Premium 2005 G35 Coupe 5AT
Angry G35 Overheating Strange Symptoms
My G35 5AT vq35de is currently over heating even after replacing the radiator and thermostat. Initial issue was a radiator leak. I did multiple coolant flushes, I bled the cooling system 100% I am getting no more bubbles with a spill free funnel with the front end lifted, but I am still overheating as I pull out of the driveway. I am currently running no thermostat that helped me drive around normally for around 7 minutes until the heat starts to spike. Heater blows hot air but he radiator is ice cold to the touch even after hard driving & the hose gets hot where it connects to the thermostat but that same hose is ice cold lower where it connects to the radiator! I ordered a new radiator cap to see if that does anything I have no leaks with a pressure test & the fluid stayed blue with a combustion test. I am at a loss & do not know what else it can be I have been working on it for months now and cannot get it to stop overheating. If any of you may know what it could be help would be greatly appreciated!!
Old Dec 10, 2024 | 02:51 AM
Scorpi0's Avatar
So the engine gets hot but the radiator stays cold?? I would think you dont have any flow then….which means your water pump isnt working.
Old Dec 10, 2024 | 03:36 PM
Yea the radiator gets no heat besides one instance when we slightly vented the air out through the radiator cap when hot being very careful of course, the radiator actually got hot but we have been unable to get it hot again what so ever even after driving around for several minutes it stays cold. I was thinking it might be the water pump but it isn't leaking or making any strange noises, the upper radiator hose does swell up when revved & I can see water circulating when I rev the engine. Maybe it isn't circulating at idle? I do notice the temperature will usually go down when the engine is revved to some extent unless its already overheating.
Old Dec 10, 2024 | 04:27 PM
HoserG35's Avatar
G35 6MT “Brembo Car”
I know you say that it’s blowing hot air, but have you been bleeding it at the coolant hose bleeder port? Sometimes you have to do it several times to get all the air out out of there.
Old Dec 10, 2024 | 10:57 PM
Yea man I bled it from there too it just spays out fluid when its hot & coolant pours out when cold. I had an exhaust leak coming from my stock y-pipe that I fixed today with a Z1 Motorsports Y-pipe got some nice gains from that according to my butt dyno even with a passenger. It would be nice if I could ride around for longer than 10 minute sessions without overheating lol
Old Jan 7, 2025 | 04:23 PM
Issue Solved!
Aftermarket radiator caps got stuck in the hose when test fitting! Pulled it out and car is now running fine!
Old Jan 8, 2025 | 08:52 PM
srv2nv's Avatar
G35 Sport
LOL Thats a new one. Glad it worked out for ya.
WadeRosenberg
Dec 26, 2021 07:57 PM
onebentvalve
Oct 20, 2017 12:38 PM
dlodeuce4
Jan 31, 2017 10:52 PM
OSKIRE
Dec 18, 2013 10:11 PM
biggerandbetter
Mar 25, 2012 09:15 AM
