Help: Anyone know where the AC takes the inside temp?
I did a double din conversion, installed all the new stuff and everything works perfectly (even the dual climate control button) except for one thing.
The AC is not reading the correct inside temp of the car. I usually have my AC set at 70 for both passanger and driver and let it be. But now it thinks 70 is -30 or something because it puts heat on at FULL blast!
The only temperature that makes it spit out cold air is when I turn it down to 60. Then the cool air starts coming. 61 and the heat turns on again.
I think maybe I didnt plug something back in since the entire unit seems to work except for the auto temperature reading.
Anyone know where I should trouble shoot this? Could something be blocked or in the wrong place?
Thanks.
-SF
Thanks.
-SF
holy crap i'm having the same problem as you, exactly as u described, and it happened right after my stereo install. glad to know i'm not the only one....now if we can just figure out what's wrong...lol
gonna ask the service guys on monday. i'll let u know..
Check this thread to solve your double din air temp issue:
https://g35driver.com/forums/audio-video-electronics/37187-doubledin-issue.html
by the drivers side feet there is a little vent like thing with a vac hose running to it. If it is not on PERFECT this will happen. sorry i didtn follow up and tell how to fix it.
-SF
-SF
Frostbite91
Aug 20, 2015 07:20 PM
