Is anyone using an oil reservior catch tank?
Old Apr 3, 2005 | 04:05 PM
gcbutter's Avatar
Question Is anyone using an oil reservior catch tank?
Hello All,
I was looking at the Nismo oil catch can, and was wondering if anyone was using the product. I did a search and could not find anything. I like to hear some reviews before I purchase the product. Also if your using a catch can, were are you mounting it? Thanks alot.
GCBUTTER
Old Apr 4, 2005 | 11:34 PM
Sickone's Avatar
I have one on order, but not the nismo.
I ordered http://performancenissanparts.com/ca...0dc5acbb37dd1a
Having seen the stuff that is inside the plenum from the PCV I thought it would be a good idea. I am supposed to get it later this week.
I plan on mounting in well at the drivers side (opposite of the battery compartment) so it is covered by the right hand drive battery cover I am putting in.
The bigger question to me is this (mind you - I haven't dug in and looked yet)
According to the manual the PCV enters the Plenum on the passenger side, but in addition a hose comes of the valve cover of the left side into the Z-tube / intake prior to the Throttle body... I know this is true since I have diconnected and reconnected it.
So it almost seems like you need two of them, but I suspect the one to the z-tube is not grabbing much. Where as the PCV is all the blowby and atomized oil vapor.
Old Apr 5, 2005 | 01:06 AM
n1cK's Avatar
G35 6MT
Question couldn't you...
couldn't you use a T to collect from both sides? i have seen this as well when i installed my plenum, and this is the conclusion i came up with. you would have to get some more hose, and route them under the throttle body, but that shouldn't be a problem.
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
Claudiu
V36 Brakes, Suspension, Wheels & Tires
Mar 10, 2018 11:38 AM
g.spot
May 9, 2016 10:54 PM
BradMD_96
Oct 6, 2015 09:31 AM
Claudiu
Sep 26, 2015 01:04 PM
