Newbie Needs help with OEM Air box
Old Apr 3, 2005 | 08:21 PM
Titaniumseeker's Avatar
Hello All:
I have a 2003 G35 sedan that I have replaced the air filter with a K&N. Unfortunately I am having trouble getting the damn box to line up with the nipple underneath. I've tried just about everything I could think of and don't understand why something this simple should be so difficult to do. Can anyone assist?? Thanks.
Old Apr 3, 2005 | 08:30 PM
300zx2G35's Avatar
No idea whats going on
I had that very same problem whenever I replaced my filter too. The only thing I can tell you is keep trying because thats all I did. I used a flashlight to look down there and just take your time and line it up. Thats the best advice I can tell you.
Old Apr 3, 2005 | 08:39 PM
Thanks for the quick response. I've been at this for a couple of hours already without results. I'll give it another go but I'll tell you I'm ready to rip the box right out. Frustration level is now at 100%.
Still at it with no luck! Got the box to line up with the nipple several times but could not get it down over the nipple I've used all my weight to push this box down and still could not get this in. This should be simple but it is turning out to be a major PITA! If anyone could shed some light as to what I am doing wrong I would very much appreciate it. Thanks
Old Apr 4, 2005 | 05:36 PM
skeleton_cru's Avatar
Sedan
I wish I could help but I didn't run into that problem. Then again I replaced the intake tube with a Z-tube at the same time.
Old Apr 4, 2005 | 07:28 PM
ChicagoX's Avatar
Don't drink and Mag Race
Is there a posssibility that the nipple may have been distorted or bent (huh huh...distorted nipple..) during full force application?
Check for debris in the socket as well. Pics?
Old Apr 4, 2005 | 07:33 PM
vleo8181's Avatar
Quick! Run to the nearest aftermarket parts supplier and buy an intake! Hahah! Doing this would get rid of all the troubles that you have now.
yosip1115
Engine - Intake/Fuel
Oct 16, 2015 11:37 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
Frostbite91
Aug 2, 2015 04:59 PM
