Quick question about Y-pipe
Old Apr 5, 2005 | 02:11 AM
taofang8's Avatar
Question Quick question about Y-pipe
Just wondering how effective these are. Planning to get the fujitsubo exhaust in a month, and wondering if I should get a Y-pipe also. Is there a difference between brands? Getting a Y-pipe shouldn't affect me in passing smog check here in california? and what's a good price for a godo Y-pipe?
Thanks so much in advance!! =D
Old Apr 5, 2005 | 02:35 AM
Cruz's Avatar
Since you're getting a Fuji regardless, I'd get a Ypipe to finish off the system. Any Ypipe will get you very similar results in sound & performance. My advice would be go for one like Gruppe S, UT or Pro 1...they're all quality pieces w/ out the high price. As long as you have stock cats a Ypipe shouldn't cause you to fail emissions.
Old Apr 5, 2005 | 02:40 AM
dklau33's Avatar
The search is your friend as there is lots of information out there on Y-pipes already.
https://g35driver.com/forums/search.php
I searched on the term "y-pipe" and got many hits.
As far as how effective they are, you will free up some exhaust flow compared to the more restrictive stock y-pipe. Will you notice any gains on the old butt dyno? Not really. I believe dynos have shown to gain ~5rwhp. You may notice a slighlty lower exhaust tone. And no, it won't affect your smog status as long as you leave the cats alone. If you're getting the fuji exhaust, getting the fuji y-pipe would be a good idea as the y-pipe outlet diameter matches up with the midpipe inlet diameter.
Old Apr 5, 2005 | 03:17 AM
taofang8's Avatar
thanks guys for the help! Y-pipe it is! =D
Old Apr 5, 2005 | 03:23 AM
Cruz's Avatar
Yeah, totally forgot about mentioning that. The Gruppe S, UT & Pro 1 all have 3" outlets that will match up w/ the Fuji as well.
Old Apr 5, 2005 | 03:27 AM
taofang8's Avatar
oh okay, so you think it really makes no difference in those companies which one I get? I noticed the Fujitsubo Y-pipes being much more expensive then those others
Old Apr 5, 2005 | 03:38 AM
Gsedan35's Avatar
I like the Tanabe and Jic myself
Old Apr 5, 2005 | 03:42 AM
Cruz's Avatar
The 3 Ypipes that I mentioned are exactly the same just w/ different names.
Old Apr 5, 2005 | 11:47 AM
Gsedan35's Avatar
The Fuji, G35 coupe and sedan system's use 70mm piping vs the 76.3mm that the Z system uses. Question I have is does Fuji make two Y-pipes, one with a 76.3mm output and one with a 70mm output (with a non sensicle crossover before the Y).
Old Apr 5, 2005 | 12:00 PM
dklau33's Avatar
I guess I was pretty lucky when I bought my NFC y-pipe when I did before they went out of business(?) Doesn't seem to be a whole lot of choices out there for stock diameter Y-pipes.
Old Apr 5, 2005 | 02:53 PM
G35STUD's Avatar
y pipe
yeah i really like the gruppe-s and the price is great, just as good as the others, just not direct from japan.... that adds price, the y pipe will make a diffrence too, with ur full exhaust sys...
skippyG
Jan 25, 2016 01:18 PM
nervseele
Engine - Exhaust
Jan 17, 2016 01:02 PM
Th611
Oct 27, 2015 03:48 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
Soumilg
Jul 18, 2015 12:33 PM
