Cutting Coupe engine cover to fit around Crawford Plenum
Old Apr 19, 2005 | 12:58 PM
ainsley's Avatar
Well, I've ordered another engine cover since I botched the existing one when I hacked it up to fit around the Crawford Performance plenum.
Here's the pic posted by Lou a while back of his custom cutting job. How did you measure and determine exactly where to cut? What type of saw did you use? I've already installed my plenum so I can't lay it on the engine cover and trace it... TIA!
Old Apr 19, 2005 | 03:13 PM
aluislugo's Avatar
Why don't you get a 350Z engine cover? You can remove the Nissan emblem and all you have to cut is the lower lip so it doesn't hit the fan. That's what I did and I really like the way it looks
Old Apr 19, 2005 | 03:40 PM
docron1's Avatar
From: Centerburg, Ohio (the geographical center of the Buckeye State)
http://www.forceinductionracing.com/cafienco2035.html
this is where I ordered my CF 350Z cover. it should be her any day now. I don't know of the quality yet but will snap pix and post them once i receive it. It is the cheapest I found so far online for engine covers.
doc
Old Apr 19, 2005 | 03:54 PM
etang789's Avatar
does any one know hows the CF 350z engine cover fit over MD spacer?
Old Apr 19, 2005 | 07:24 PM
lowrider's Avatar
Hi ainsley
I first took a piece of cardboard and cut it roughly to shape, being careful to keep if oversize. Once I had it the way I wanted, I laid on the cover and marked the cover with marker. I then cut the cover with a dremel tool. As I said it was slightly oversize. I then trimmed it down in stages until it fit. Hope this helps.
Oh, and if you look at the left side, you'll see a bolt and cap that I added to the cover to keep the back bolted down. I turned one of the bolts on the plenum into a stud for mounting the cap.
BTW, IMO, the "Z" cover doesn't really fit the "G", because it contacts the center scoop. It's longer than the "Gs" scoop. The "Z" doesn't have the center scope.
Lou
Old Apr 19, 2005 | 09:03 PM
Vic's Avatar
Vic
what do you mean by the Z cover does not fit the G? I thought that they have the same fitment.
Old Apr 19, 2005 | 10:19 PM
ainsley's Avatar
Thanks Lou! Thanks guys. Aluislugo and Doc, be sure to post pics of yours.
Old Apr 19, 2005 | 10:42 PM
DaveO's Avatar
I didn't have any Z cover fitment problems with either the stock upper collector (plenum) or with it modified to fit the Crawford V5.
Attached Thumbnails Cutting Coupe engine cover to fit around Crawford Plenum-g35s-z-cvr-duct-k-n-drop-air-filter.jpg   Cutting Coupe engine cover to fit around Crawford Plenum-s-engine.jpg
Old Apr 20, 2005 | 12:56 AM
Vic's Avatar
Vic
thanks for the pic dave, it looks really nice. Actually I'm getting the carbon fiber one.
Old Apr 21, 2005 | 06:42 PM
Gumba35's Avatar
I wish somebody sold a template. I've been wanting to do this but I don't want to screw it up.
Old Apr 21, 2005 | 10:36 PM
ainsley's Avatar
G35Sean: I agree! I just came in from the garage after screwing up my second engine cover in a row. I messed up sawing the first one a few days ago. So I bought another and mis-measured the frickin' thing a little so it's crooked. It's not terrible, but not perfect like I wanted. So out of sheer stubbornness I'm going to get a third one and keep at it until one comes out beautifully. Son of *&%$^!!!!
DaveO: How exactly did you modify your Z engine cover to fit the Crawford plenum? Thanks.
Old Apr 21, 2005 | 10:37 PM
ainsley's Avatar
If I ever get this right, I will create a template that can be downloaded and printed on paper or something like that!
Old Apr 22, 2005 | 08:15 AM
Gumba35's Avatar
ainsley-How much are the engine covers? It must be getting expensive. If you create the template PLEASE let me know.
Old Apr 22, 2005 | 09:10 AM
irony's Avatar
I have also hesitated cutting the cover; I have a history of screwing up "simple" things. Help me by creating a template
Old Apr 22, 2005 | 10:14 AM
Gumba35's Avatar
ainsley-The link to your DIY and reviews is very impressive.
