Spacer installation question
Old May 2, 2005 | 04:54 PM
Napoleon's Avatar
Originally Posted by lgangi
....And finally, I'm thinking that the 40-61 in-lbs of torque may not be right. Looking at the Infiniti shop manual and a Stillen install guide this AM, they both reference 9-10 ft-lbs. That's about 2x what's being recommended....
You may be right about that 9-10 ft-lbs...
Check out these 2 attachments.
I looks like just the studs want 40-61 in-lbs...the rest of the plenum wants 9-10 ft-lbs....
anybody concur?
from the downloaded 2004 G35 Coupe service manual:
Attached Thumbnails Spacer installation question-plenum2.jpg   Spacer installation question-plenum.jpg
Old May 3, 2005 | 01:46 AM
drsifu1's Avatar
Staff ALUMNI
20 Year Member
i tightened all the supplied bolts to 115 in/lb. everything looks and sounds good.
don't really understand the 60 in/lb instructions.
Old May 3, 2005 | 09:28 AM
wanalaugh74's Avatar
Are there different settings for different bolts for the coupe and sedan? I just did the 5ft/lbs for every bolt, per Tony's instructions. I did notice after a couple of days, i had to re-tighten 2 bolts. Does anyone know if this will be a reoccurring theme?
Old May 3, 2005 | 12:45 PM
P_Diddy's Avatar
By the way, just an engineer's nit pick.....it's in-lb, not in/lb (which is inch per lb).
It is in-lb because torque is the product of a perpendicular force applied a given distance (moment arm) away from the bolt....so it's in x lb
Old May 3, 2005 | 12:46 PM
P_Diddy's Avatar
If you tighten them again but they still get loose, you need to tighten them down more by 1 or 2 ft-lb.
The OEM bolts had a finish on them, anyone know what it is? Galvanized?
Old May 3, 2005 | 03:49 PM
drsifu1's Avatar
Staff ALUMNI
20 Year Member
thanks for the correction and explanantion
jsimonk
Dec 22, 2023 03:49 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
EnCr1pt3d
Jul 29, 2015 03:35 AM
Soumilg
Jul 18, 2015 12:33 PM
