Kinetix plenum and engine cover
I am wondering if anyone with the Kinetix V4 intake plenum has been able to reinstall their engine cover without having to hack it all up? Also the same question with the APS intake plenum. Finally, has anyone had any problems with either intake plenum and what have you done to resolve the problem?
i was able to reinstall my stock engine cover to its original place but i had to cut a very small plastic away at the elbow near the throttle body. plus i had to make a special bracket to mount the rear left bolt.
Originally Posted by aluislugo
I bought a 350z enigine cover and cut off the front lip so it does hit against the fan. Looks nice. Also be sure to remove the nissan emblem.
Originally Posted by SLVRG35
No modification needed for mine
Originally Posted by Mr_pharmD
damn that looks sweet!!!!!!!!!!! Did u have to get different washers and screws or did u use your stock ones? Also, i heard the cover is close to the fans is that true and does it rub?
