overreving engine
Old May 14, 2005 | 02:51 PM
badtz's Avatar
overreving engine
what would happen if you overrev your engine? what kind of sound would it make and what would be the symtoms? smoke? grinding noises? would it be possible to overrev your engine and not notice/hear any damage assuming something happens in the engine that's not supposed to happen due to overreving?
Old May 14, 2005 | 03:48 PM
Msedanman's Avatar
O.F. Administrator
Don't do it man, it'll explode into a bazillion pieces. OUCH.
C.
Old May 14, 2005 | 04:11 PM
badtz's Avatar
are you serious are are you joking...?
Old May 14, 2005 | 04:47 PM
Farch's Avatar
The fuel is cut off before you can do damage. I happen to hit red line last week by mistake and the fueling was cut and RPMs dropped. I shifted and went on my way
Old May 14, 2005 | 04:57 PM
badtz's Avatar
that's if you have a rev limiter. my rev limiter has been removed by Technosquare.
Old May 14, 2005 | 05:41 PM
jwg35c's Avatar
I'm not sure but if you do will you post what happens.
Bazillion pieces. HaaaHaaaa
Old May 15, 2005 | 04:24 AM
some2's Avatar
You will blow your motor (throw a rod, lean out the fuel too much, etc..) if you do it excessively.. You can probably get away with 7400rpm or so, but if you peg your tach you're not doing good things to the motor. You're almost better off having a rev limiter because you are well on the downward side of the HP/torque map by the time you hit 7000rpm. Consider a shift light if you're really serious about this stuff.. they're cheap and easily setup. Set your light to optimize the torque/hp.. not to go as high up the tach as possible.
As for what you will hear.. there was a SC Cobra vs. Vette video where the guy throws a rod.. probably from leaning out the engine too much.. used to be at http://www.corvettekillstories.com/v...bra_vs_Z06.wmv.. might come back some day? Basically, the engine just starts making really loud knocking noises and substantially loses power.
Old May 15, 2005 | 08:46 PM
copbait's Avatar
Why would anyone ever remove a rev limiter? I could see increasing it, but removing it totally?
Old May 16, 2005 | 01:43 AM
badtz's Avatar
I didn't remove it on purpose. I think technosquare messed something up.
Old May 16, 2005 | 12:40 PM
DaveB's Avatar
It's impossible to overrev an automatic unless you've got a 7000+ rev limiter or no rev limiter. With a 6 speed, it's quite easy to overrev the motor by misshifting into too low of a gear at high speed (ie going into 2nd thinking it was 4th at 95mph). No type rev limiter will save you if you make a mistake like that.
A handful of things can happen if you overrev a VQ motor:
1) Bend a valve. You'll hear a loud ticking if it happens.
2) Throw a rod. The VQ35 has very weak rods and they don't like high rpm speeds (7000rpms+). The engine will die and you'll see lots of smoke and oil and maybe coolant pour out the bottom of the car.
3) The clutch may blow up. This had happened to a couple VQ30 Maximas on misshifts.
4) Blow a headgasket. I know of two VQ30 Maximas with 7500-8000rpm limiters and both have had headgasket failures. If this happens the engine will run crappy, it may smoke (white), and oil and/or coolant will look frothy. I imagine the cause was that the water pump cannot move the coolant adequately at rpm high speeds.
5) Spin a crank bearing.
Freeman186
Sep 6, 2023 10:07 AM
alessandro
Oct 8, 2015 09:29 AM
Joe Gargano
Sep 18, 2015 11:17 AM
AT23
Sep 15, 2015 07:44 PM
AuAltima3.5
Sep 13, 2015 10:53 AM
