tools for oil change (G35 sedan)
Hi guys, going to do my own oil change.
However, I need to know what socket size is required for the drain plug and what type of screwdriver needed for the plastic
cover below the oil pan. For those who have done it,
I thank u in advance for the info.
My G is absolutely "Mavelus"!
Re: tools for oil change (G35 sedan)
look at the thread on oil change in the g35 sedan general forum. also the drain plug is a 14mm 25-30 ftlb
you will need an oil filter wrench of some sort (i used a screwdriver) the first time you change your oil
Better Life thru Chemistry
kinetek
Aug 3, 2015 04:25 PM
laksjd84
Jul 24, 2015 05:12 PM
newbdriver01
Jul 15, 2015 06:10 PM
