3/8" Morordyne Plenum Spacer
Old May 31, 2005 | 11:26 AM
coupin827's Avatar
Has anyone who has this installed experienced any rubbing w/ the engine cover on.
I saw a buddy of mine's and his was rubbing, this is the only deterrent right now to get this.
Thanks.
Old May 31, 2005 | 05:14 PM
SagiSRP's Avatar
only the top right part is rubbing.. but nothing big.. if its a problem than just take the cover off.. or get the 1/4".. but if you're going to take the cover off than might as well get the 1/2"
Old May 31, 2005 | 07:09 PM
AzSi22's Avatar
Mine was rubbing slightly, so I took the rubber grommets off and placed them on top of the cover instead of under. No more rubbing.
Old May 31, 2005 | 07:44 PM
headpaneer's Avatar
Where is the rubbing occurring at?
Old May 31, 2005 | 09:31 PM
P_Diddy's Avatar
looks like you can take off the spacers under the cover to lower it down
https://g35driver.com/forums/g35-coupe-v35-2003-07/55814-3-8-motordyne-plenum-spacer.html
Old Jun 2, 2005 | 02:45 AM
headpaneer's Avatar
Cool. Thanks for the link. I have a 3/8” spacer in the trunk that will be installed soon. Nice to know about a fix in case my car is that 1 out of a 100.
Old Jun 2, 2005 | 02:00 PM
triniG35's Avatar
Yes mine rubbed with the 3/8 also.
Old Jun 2, 2005 | 09:13 PM
Balzz's Avatar
I removed my hood liner to alleviate the rubbing.
Old Jun 3, 2005 | 03:54 PM
P_Diddy's Avatar
This should work.....Remove the engine cover and on the underside, there are 2 metal washer/grommets stuck on the top holes. Remove those and squeeze out the rubber bushing. Flip the bushing so the fatter part is now on top and re-install. Then re-install the metal washers and install the engine cover.
This will not lower the cover by much, but it may be enough to prevent the rubbing.
Red G Coupe
Tuner & Dyno
Jan 14, 2016 01:13 AM
prinny
Nov 22, 2015 11:07 PM
w4kj4k
Oct 2, 2015 07:57 PM
thechitoguy
Oct 1, 2015 05:25 PM
BradMD_96
Intake & Exhaust
Sep 28, 2015 06:25 PM
