If you have hotchkis swaybars, please read.
Old Jun 3, 2005 | 06:13 PM
g35cas's Avatar
After ordering hotchkis swaybars I came across a problem with these swaybars. They don't have collars to prevent them from moving side to side(oem and other aftermarket have collars). This link is a quick and easy fix for this problem. http://www.my350z.com/forum/showthre...t=hotchkis+fix
Many people who have hotchkis and are taking their cars to the track were noticing that their swaybars were pushed to one side or the other. Hopefully this will help those people out. I did the same fix to my sways.
Old Jun 3, 2005 | 07:31 PM
bzabodyn's Avatar
this is pretty old news, as I was one of the first people to add the collars quite some time back... but definitely something that needs to be purchased in addition to the swaybars themselves if you want them to perform how they are meant to...
Old Jun 6, 2005 | 04:29 PM
Aznteazer's Avatar
i was reading the link about the fix, but im still not clear on how much freeplay u're supposed to leave. the collars shud arrive today or tomorrow.
Old Jun 6, 2005 | 05:02 PM
THX723's Avatar
G Kreuzer
2-3 mm is enough free play for the collards.
Be wary the front bar will not accept conventional collards correctly due to the non-ideal curvatures. The rear bar, being very staright, works well w. those collards.
Old Jun 6, 2005 | 05:37 PM
Aznteazer's Avatar
wat did you use for the front collars? have part # and company u ordered from?
thanks
Old Jun 6, 2005 | 05:42 PM
THX723's Avatar
G Kreuzer
Non of the off the shelf aftermarket ones will work properly ... they are meant for staight bars. I have a custom piece welded onto the bar.
Old Jun 6, 2005 | 06:25 PM
g35cas's Avatar
If you look at the stock swaybars, they have very little(if any) side to side free play. On the collars for the front, I just left enough room for rotational movement. They did fit, but had to put them on the first part of the swaybar bend. I have no noise or other problems after this fix. I'm sure welding a collar is a better answer, but either solution will work.
Old Jun 6, 2005 | 06:36 PM
Aznteazer's Avatar
forgot to mention, my sway bar linkage was replaced at the dealership while i was getting my car serviced.
this might have had to do with the missing collars...
g.spot
May 9, 2016 10:54 PM
prinny
Nov 22, 2015 11:07 PM
dorkstar
Steering & Suspension
Sep 16, 2015 01:02 AM
G35VSHNG37
Sep 10, 2015 01:54 PM
