MOTOR OIL
Old May 2, 2008 | 10:53 PM
lekker_droom's Avatar
sweet
Old May 2, 2008 | 10:57 PM
LightsOut's Avatar
SIETESG
dang 2002
i had a mazda truck then
Old May 3, 2008 | 03:00 PM
Canadian's Avatar
Canada, eh?
Originally Posted by Johnny'sG
Whatever you do, do not switch to any synthetic oil until you hit around 10,000 miles. The synthetic oil will push through your engine rings and your G will begin to burn oil very lightly, but enough to notice. Stay with non- synthetic oill until past the break in point, which is 10,000 miles or so. Trust me. Even 4,000 miles is not enough! I just saved you around $5,000 to replace your rings! Well, maybe warranty would cover the damage.
Not true at all, I switched to synthetic on my first oil change and I put 6qts in and get 6qts out.
I use Amsoil 0w-30. I need 6 qts because of my oil pan spacer, the G uses 5 for anyone that doesn't know.
Wow, I just realized this thread is like 5548541851 years old.
Old May 3, 2008 | 04:29 PM
bythabay's Avatar
+1
I switched over to Amsoil full synthetic after only 100 miles on the odometer. My consumption is only 1qt in 7500 miles and I'm almost at 60k. I was considering an oversize pan also for improved contaminant dispersing and cooling. Which one do you have? Was it hard to get it to seal well after you installed the new one?
I was looking at the new stillen one in their new catalog.
Old May 3, 2008 | 04:30 PM
bythabay's Avatar
The only real reason (in my opinion) to not use synthetic until after about 15k is because the wear metals will be high when the engine is new (and silicon will be high too).
Old May 4, 2008 | 07:03 PM
mwarsh1's Avatar
Is Amsoil Better Then Mobil1 I Have Been Using Mobil 1 Since 200 Miles.
Old May 6, 2008 | 05:24 PM
bythabay's Avatar
In my opinion yes, because of the better additive package. Mobil 1 is API approved, whereas all Amsoil oils, with the exception of the XL7500 are not API approved (but meet the specs). This is due for one or both of two reasons:
a) licensing costs money and Amsoil doesn't want to have to past that cost on to us.
b) Amsoil uses really high levels of some additives that "supposedly" can damage catalytic converters if large amounts of those additives are deposited inside the converters.
Even if this is the case, you probably have other serious problems if you're burning that much oil and for myself, I have a spare set of converters laying at home just in case
Seriously though, I've never heard of any catalytic converter failures as a direct result of Amsoil usage.
alessandro
Oct 8, 2015 09:29 AM
JLee301
Sep 25, 2015 08:46 PM
CV35Driver
Sep 15, 2015 05:09 PM
UT G35
Sep 3, 2015 03:58 PM
