Question about nitrous
Old Jun 23, 2005 | 03:18 AM
weslutes's Avatar
I bought the universal MSD Window switch for about $100 and used a 30amp relay switch.
The n2o doesn't turn on untill I'm WOT,above 3900rpm,and the foot rest switch is released.
I'd like to get the NX maximizer to help deal with current traction problems.
Old Jun 23, 2005 | 08:31 PM
RedondoG's Avatar
Originally Posted by ducatiguy
There's no "thingy" (well atleast nothing off the shelf or that comes with any system on the market right now) that tells (or that will cut) the nitrous system if your engines running lean. The system is either on (spraying) or off. A setup like that is possible and some do have it, but these are hardcore racers who are running custom mapped ECU's designed JUST for nitrous use and or have custom nitrous fual / ignition modules doing the same job. For your "stock" setup, it's all in your hands, and everyone keeps mentioning just make sure you run rich, but here we have someone asking BASIC info about a nitrouse system, and most likley does NOT know how to "run rich" or even perhaps what it takes. Adding an extra fuel pump will make certain you have the needed fuel supply, but depending on your fuel delivery (setup) it may not be enough. You will most definately need an adjustable EFI rated (hi-pressure) fuel pressure regulator and or ECU tunning (to electronically compensate for the richness). Going a 1 to 2 heat ranges colder than stock with plugs is also a good idea, but stay away from "but plugs"! NO I dont mean SEX toys, a "but plug" is known as of them fancy plugs that sell for like $30 a pop and when you go to buy them, the guy does down the list and says but these plugs have so and so, but these are better, but this, but that, but... Stay away from the "buts". Simple is always better!
WRONG!
Actually Venom sells a dry kit (VCN 1000) that cuts off the nitrous if the engine runs lean. A higher pressure fuel pump is a good idea though.
bryanr
Drivetrain
Sep 30, 2015 06:31 AM
JG_G35
19 Inch
14
Sep 19, 2015 09:04 PM
migurus
Sep 5, 2015 09:39 PM
SilverG123
Engine - Electrical
Sep 4, 2015 01:12 PM
TheBay
Sep 3, 2015 03:27 PM
